Who has pressed the Start button while in motion?
Discussion in 'Gen 2 Prius Main Forum' started by Basildane, Jun 30, 2006.
  1. Basildane
    Basildane Junior Member
    46
    Have any of you selected Park or Reverse - while driving?
    I'm not going to try it, but having that button right in front of me is tantalizing! I can't stand it.
    I must know what happens if you press the Start button at 30 mph.
    Has anyone tried?
  2. aaf709
    3,862
    2022 Prius Prime
    I've heard it's either nothing or goes into Neutral. It's pretty protective.
  3. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    nothing happens when you're in motion. i personaly didn't try it, but i was giving a friend a ride home from one of our parties (she was fairly drunk), and she just leaned over and started poking the buttons... scared me for a second, but everything continued to work just fine!
  4. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    I was on a flat, straight, abandoned road and decided I'd give it a try (pushing the Power button while in motion). I wasn't completely in the dark, since I had heard from people here what happens. Anyway, if you just push the power button briefly, nothing happens. However, if you hold it down for a few seconds (maybe ~5 seconds), the car will shut down. The only thing visable will be the gear indicator (which will show that you're in neutral). In order to get back into a "normal" state, you have to bring the car to a complete stop, shift it into Park, and push the Power button again.
    Never tried pushing the "Park" or "Reverse" button while moving, but someone here says the car just beeps at you if you're traveling at any reasonable speed.
  5. Basildane
    46
    Thanks folks. Now I may rest easy.
    I wonder if there is a cutoff speed (like 1 mph) where it would lockup though?
    I'd love to see the software.
    If I wrote it, I would have the system wait 500 ms after the wheels have stopped completely, then park and shutdown.
    From what I've seen so far on this car, they haven't overlooked anything.
  6. Betelgeuse
    1,460
    24
    New York, NY, USA
    <div class='quotetop'>QUOTE(Basildane @ Jun 30 2006, 02:18 PM) [snapback]279226[/snapback]</div>
    I think I recall reading here that if you push Park when moving slowly (1 or 2 MPH), it WILL go into Park (and jolt you to a stop). Probably not very good for the parking pall, so I think I won't be trying that.
  7. JackDodge
    JackDodge Gold Member
    2,366
    Bloomfield Hills, MI
    Well, the first Prius I had, it blew up when I did that so I don't do it with the one I have now.
  8. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    ya i tried it. not much happens. any momentary push or shift into anything but neutral does nothing. shift and hold a sec and if its an invalid shift you will get a beep. hold it for two seconds it shifts to neutral
    the power button will shutoff the car if held for a few seconds. other than loss of power steering, (most of you have noticed that there is no steering wheel lock...makes sense since there is no key to turn) nothing much happens. if moving you can power back on into neutral (not park as some might think) without much ado and without pressing brake as you normally would.
    p.s.
    some of you may think me either brave or foolish for having tried all this, but i have confidence in Toyota's ability to idiot proof their products... but keep in mind, there is always a bigger idiot out there
  9. onerpm
    onerpm New Member
    477
    MN
    <div class='quotetop'>QUOTE(Betelgeuse @ Jun 30 2006, 01:38 PM) [snapback]279236[/snapback]</div>
    you are correct about that. happened to me once, I think I was easing back out of my driveway or something.
  10. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    there is a speed zone that all controls do as they are designed. it is pretty low. this was done to enable rocking the vehicle. a few have posted this fact which allows shifting from drive to reverse and so on without braking first. all my tests were done at around 25-30 mph
  11. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(Basildane @ Jun 30 2006, 11:18 AM) [snapback]279226[/snapback]</div>
    Except for a way to plug it in. :lol:
  12. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    <div class='quotetop'>QUOTE(DaveinOlyWA @ Jun 30 2006, 03:47 PM) [snapback]279275[/snapback]</div>
    when i back into a parking spot in the morning (they're hard to grab with so many people flooding the lot at 8:50am) i'm usually in a hurry to get out of someone's way so i just drop it into reverse while still moving slightly forward at ~2 mph. haven't had any trouble.
  13. IHeartMyPrius
    IHeartMyPrius New Member
    yea buddy, throw it into park going 55 down the interstate
  14. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    <div class='quotetop'>QUOTE(IHeartMyPrius @ Jul 3 2006, 11:49 PM) [snapback]280897[/snapback]</div>
    Unless you hold the Park button in, nothing happens. This is a wire-line car, not a mechanical marvel.
  15. Jeannie
    Jeannie Proud Prius Granny
    1,414
    Central New Jersey
    <div class='quotetop'>QUOTE(Bill Merchant @ Jul 4 2006, 04:39 AM) [snapback]280921[/snapback]</div>
    My older son tried out my Prius while I was up in MA visiting for the weekend. He had pulled over to the side of the road to try calling out on his bluetooth phone, put on the flashers, made his call, pulled back on to the road and then hit the Park button instead of the Hazard Light button, causing the car to jolt to an immediate stop from its 2-3 MPH speed. I think I like his bluetooth phone better than his driving<g>
  16. barbaram
    barbaram Active Member
    912
    70
    Trenton, NJ
    I would be extremely careful about shifting from forward to reverse or vice-versa expecially in electric mode! COME TO A STOP FIRST!
    This can damage the electric motors!!!
    It is a technique if the air brakes fail on a diesel-electric locomotive called "plugging the motors" to attempt to stop it. change from forward to reverse while the motors are running and it will burn them up!!!!
