Who still has the 'original spark-plugs'-How many miles on the Prius
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Aug 29, 2023.
  1. ski.dive
    ski.dive Active Member
    895
    231
    Hutchinson Island,FL. Mt. Snow,VT
    Who still has the 'original spark-plugs'?
    -How many miles on the Prius?
    My 2008 Prius has 124k miles and still has the original spark-plugs
  2. Tombukt2
    Tombukt2 Senior Member
    9,075
    1,574
    Durham NC
    Well it's about past time to be changing them pull them out take pictures whatever but change them those are generally hundred thousand mile plugs under ideal conditions so you might want to have a look or whatever.
  3. Tombukt2
    9,075
    1,574
    Durham NC
    I've seen him come out with almost no electrodes on them at 150 160K
    49,435
    87,000, but i am getting some misfires
  5. mr_guy_mann
    mr_guy_mann Senior Member
    3,456
    1,503
    NJ-USA
    I find this a little bit odd...like boasting how old your socks are.
    Spark plugs are a wear item and should be replaced BEFORE you start having misfire problems (unless you plan on just replacing all the coils at the same time anyways).
    I guess there aren't too many people here who knew what it was like in "the good old days" of old cars. You had to replace breaker points, condenser, plugs, cap, rotor, plug wires - typically around 30,000 miles. Sooner if your engine burned oil and fouled the plugs.
  6. dolj
    dolj Senior Member
    7,645
    3,858
    Wellington, New Zealand
    Fun times, thanks for bringing back the memories! (y):sneaky::)
  7. rjparker
    rjparker Tu Humilde Sirviente
    7,961
    4,709
    Texas Hill Country
    Agree and they still run fine. The ignition system burns through oil and coolant.
    Tombukt2 likes this.
  8. Leadfoot J. McCoalroller
    7,162
    6,712
    Pennsylvania
    2018 Prius c
    I couldn't afford anything remotely new when I started driving. My first (very used) car needed valve adjustments twice a year, wheel bearing re-packs and spark plugs annually. Can't remember how often I needed to set dwell angle or change points.
    After a couple of years I was good at doing it all myself with a toolkit that weighed less than 10lbs and stayed under the back seat.
  9. lexidium
    lexidium Active Member
    236
    110
    manchester
    Get them changed and stop messing about . . . . . .
  10. Tombukt2
    9,075
    1,574
    Durham NC
    Well I had British Leyland vehicles quite a bit had British Leyland vehicles
    He he he . I grew up messing about with British Leyland cars triumph spitfires TRs MGs that sort of thing of course Volkswagen.
  11. Grzldvt
    Grzldvt Junior Member
    34
    17
    Coarsegold, CA
    I am guessing mine are at 110k+ miles. The person I got the car from always changed the oil and filters, but told me today she never changed the spark plugs. So I will be doing that next weekend,
