Why a cabin air filter?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Metalman, Jul 10, 2013.
  1. Metalman
    Metalman Member
    107
    17
    Summer, KY; Winter FL
    I've replaced the cabin air filter and within less than a year it smells again due to mold. Since not all vehicles have a cabin air filter, I wonder what harm would be done by just eliminating it.
    Thanks
    kboofan likes this.
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    The mold is probably in the entire system and not just in the filter. I suggest you find someone who can disinfect the entire intake system.
  3. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    Removing it will screw up the air flow into the blower. Try one of the filters with charcoal (grey color) if you haven't already.
  4. Tideland Prius
    16,155
    Other than your health, (and possibly the fan if something gets caught in it rather than getting caught by the filter) not much. Given how dirty my filter looks after 6 months (oil refineries and plastic plants), I'll keep mine.
    fuzzy1 likes this.
  5. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    that's why its recommended that the cabin air filter is replaced every 15k miles :)
  6. MPGnutcase
    MPGnutcase Active Member
    579
    114
    Chicago
    Keep the filter clean and if you take it out for good all the crap that it sucks in will mess up you A/C and heater.
    And that will be costly
  7. Bill Norton
    Bill Norton Senior Member
    1,844
    603
    MONW, Ks.
    Pull the old filter out and smell it.
    I doubt that is where your moldy smell is coming from.
    The AC evaporator is where the water condenses out and drains to the ground.
    Mold can grow in that area, not on the air filter which remains dry.
    There is a procedure for killing the mold in the evaporator section of the system, and making sure that chamber drains to the ground freely.
    I don't know what that procedures is. I would think it involves bleach....
    Good luck with the research and leave the air filter in place. It most likely is not the problem area.
  8. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    If you leave it in recirc 100% of the time the system could get moldy regardless of how often often you change the filter. I doubt it's the filter and what you need to do is switch to outside air often rather than leave it in recirc all the time.
    jgilliam1955 and Stevie like this.
  9. Tideland Prius
    16,155
    Mine doesn't last 15k miles. It's black at 5k miles :eek:. Back home, it'll last at least 10k or 1 year before I need to replace it.
  10. Tideland Prius
    16,155
    Are you living in a humid environment? I would suggest running the fan for a few minutes (With the A/C off) before shutting off the car. (or just turn off the A/C a few minutes before you reach your destination). This will help reduce the amount of moisture build up.
    Earthrise likes this.
  11. NutzAboutBolts
    1,476
    1,552
    Bay Area
    true to certain people at certain places. I've seen it myself :(
  12. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    This is my second car with a cabin filter. My previous cars did not have one. I never replaced the filter even after 150k miles. I don't plan to replace this one either. I have no doubt it works but the instant you open the door or window, you have ambient or "dirty"air. I think Toyota wants to charge you more money to replace a consumable. The follicles in my schnozz will suffice for me.
  13. Stevie
    Stevie Junior Member
    95
    22
    Melbourne,Victoria,Australia
    can you get a disinfecting type aerosol there ? if so I suggest you use it, both inside the car and on the outside where the air is drawn in, the product here in Australia is Glen 20, other than that, avoid the use of recirculated air, it is just stale air going around and arund inside your car hence moisture mould smell etc,
    brief description of Glen 20 from their blurb -
    • Killing 99.9% of germs* and viruses** on hard and soft surfaces.
    • Eliminating odours caused by bacteria and leaving your home smelling wonderfully fresh and clean. It tackles unpleasant odours, for example in musty areas where air doesn’t circulate, without heavy perfume – something a non-germicidal cleaning spray can’t offer you.
    • Killing the source of mould allergen and controlling the growth of mould and mildew on hard surfaces.
  14. Tideland Prius
    16,155
    I don't know if you mean that you wash your own filter and reuse it but if you don't, it won't cool down as fast and it won't defrost as fast. It might not matter since you're in CA and it seems you prefer to open the window instead. For those that require a defog in the winter, a clogged filter will reduce the drying effect.
  15. Metalman
    Metalman Member
    107
    17
    Thanks for the quick replies to my question about removing the cabin air filter. The Prius is about 2.5 years old and has about 12,000 miles. It is driven only in KY in the summer and is stored in the garage under the house during the winter. When I changed the filter at well under 10K miles, it was heavily contaminated with smelly mold. The car is seldom run with the air recirculating and the AC is run about 50% of the time. The suggestion of drying it out by running the blower without the AC sounds reasonable, but I don't know how humid air will dry out the filter. Perhaps spraying a disinfectant in the filter and the evaporator will cure the problem. But I still don't understand how other vehicles can be designed without cabin air filters and seemingly operate without producing heinous effects.
  16. El Dobro
    El Dobro A Member
    6,979
    3,214
    More and more cars are coming with cabin air filters to keep pollen, dust, etc from blowing through the vents. It's not there to prevent mold, so if there's mold on the filter, there's mold on the evaporator. The products on the market to correct the problem usually have to be sprayed onto the evaporator directly by drilling a hole in the case.
  17. ursle
    ursle Gas miser
    1,049
    192
    NH
    All that the prius is doing different than a non interior cabin filtered car is showing you the mold that's growing everywhere... when you seal up any vehicle in a dank musty environment.
    The filter is there to keep dirty, smoggy, dusty and pollen "ridiculed" air from entering the cabin while the car is passing thru areas that are dirty, smoggy, dusty and pollen "ridiculed"
  18. rdgrimes
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    More than anything, the filter is there to protect the evap coils and heater coils from clogging up with the same crap that clogs the filter. It effectively doubles the life of those components and keeps them working at peak efficiency.
    Jon Hagen and edthefox5 like this.
  19. mmmodem
    2,732
    1,703
    Bay Area, CA
    I honestly never looked at the filter. I mostly drive with the vents open and windows up. AC performance did decrease over the years. One AC recharge took care of it. I didn't notice any other problems but perhaps you are right that my temperate location affords me more leeway.
  20. MPGnutcase
    579
    114
    Chicago
    A cabin filter is a cheap item to replace (y)
