why a scan gauge?
Discussion in 'Gen 2 Prius Main Forum' started by cvincent, Feb 24, 2010.
  1. cvincent
    cvincent Junior Member
    76
    arizona
    ok i have scan gauge on both of my trucks, running trans, mpg, volt, etc
    the main thing i use this for in the truck is the mpg
    but the pri has that thing on the mft telling you the mpg, soooooo?? why does everyone want one?
    what else are you doing with it to help with mileage?
    i havent picked up my car yet so have only briefly looked at a pri dash at all, but i did notice the spinning wheel thing and the mpg at the bottom
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,120
    SF Bay Area, CA
    http://priuschat.com/forums/gen-ii-...angauge-best-threads-mileage-improvement.html is a good starting point. http://priuschat.com/forums/gen-ii-.../74368-scangauge-newbie-suggested-gauges.html sorta answers your question.
    FWIW, I've tried to use it for SHM but never was really patient enough nor had a long enough, clear stretch to do it much w/o putting myself in danger. I mainly use it more out of curiosity, to gauge how hard to brake to not throw away energy (as heat and brake dust) and to know when to turn the HVAC to off (when temp is above lo) so that the ICE doesn't fire up (boundary is at 145 FWT [Fahrenheit Water Temp]).
    Some use it to be able to tell what "stage" they're in (see 1st link).
    Don't get too distracted by the Prius' displays and ScanGauge at first! I was overwhelmed by the amount of Prius related ScanGauge knowledge, posts, etc. when I first got mine.
  3. MJFrog
    MJFrog Active Member
    780
    266
    NE Oklahoma
    2018 Nissan LEAF
    I have mine set to display RPM, fWT (water temp), bta (battery amps +/-) and SOC.
    This tells me if I'm pushing the engine too hard (rpm) or if it's off; whether the engine is warm enough to go into S4 (fWT); how much I'm regenning or using the HV battery (bta); and how much HV battery is left (SOC).
  4. cwerdna
    12,544
    2,120
    SF Bay Area, CA
    I use the above too for most of my current driving. If I'm at highway speeds or might be in situation to do SHM, I'll tend to switchover to show IGN and gps (gas pedal position sensor) and leave RPM up.
  5. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    502
    63
    +1. Wise men think the same. :D
    I used to use IGN for SHM but then I found it much easier just to look at the instantaneous MPG bar graph from the MFD - there is a quantum jump up in instantaneous MPG when entering SHM.
    Hope this helps and enjoy the new car! :)
  6. cvincent
    76
    arizona
    obviously i have a lot of reading and researching to do for programming the scan gauge, etc
    thanks for all these links
    will get on that when i pick my car up this weekend
  7. RobH
    RobH Senior Member
    2,368
    975
    70
    Sunnyvale, California
    I use a ScanGauge to turn off the backup beeper on my friends 2010s.:p
  8. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
    I use mine for battery voltage, both with car running and engine(s) off. Also for RPM. Wish there was a way to get oil pressure!
  9. djasonw
    djasonw Active Member
    942
    112
    Coconut Creek, FL
    I'm going to definitely purchase one. Will the unit have instructions on what functions can be monitored on the Prius? Is it user friendly? Thanks
  10. 2009Prius
    2,705
    502
    63
    The best way to find out the functions is just to search on the web. There are some posts about it right here in priuschat.
    It is somewhat user friendly once you get used to it. The most painful part is to manually enter the codes for X-Gauges (additional functions that is not built in) but you only need to do it once. Hope this helps. :)
  11. cwerdna
    12,544
    2,120
    SF Bay Area, CA
    Not for ones that aren't built in. As for the latter, sorta.
    This is probably the best list I know of so far:
    http://priuschat.com/forums/gen-ii-...77-updated-list-gen-ii-xgauges-scangauge.html
    Agreed. Putting in the X gauges is a pain. For each XGauge you want, you have to enter all hex values for that row + a name (NAM) using the couple buttons that are on the unit.
  12. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    I'd like to get a scangauge eventually. I think I'd run RPM, Coolant temperature, SOC and charge current.
    I've taken to turning the MFD off when I leave for work (I leave the house after 9:30pm), and having a ScanGauge could help me monitor things I'd like to see relevant to how the car is performing without having to use the MFD.
  13. youngnbald
    youngnbald Junior Member
    66
    Bloomington, Illinois
    2001 Prius
    I
    What are the values you see with the BTA and SOC? I just hooked my scan gauge up and would like to know the common values that would or should be seen.
  14. 2009Prius
    2,705
    502
    63
    They depend on your driving conditions, though you should not see SOC above 80% or below 40% very often at all. Here is a graph of the data that I collected some time ago:
Loading...
