Why am I getting exhaust fumes in cabin
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Adrian Bryan, Dec 6, 2021.
  1. Adrian Bryan
    Adrian Bryan New Member
    Colorado
    After searching the forums I can’t find anything that sounds like my problem.
    I have a 2013 Prius 3 with a 2016 engine. I replaced the bad engine with a 2016 engine with 55k miles. I’m starting to think I have a cracked exhaust manifold or something. Every time I turn on the auto setting for the ac and it uses the outside air I get a massive amount of exhaust fumes while idling somewhere. It has started more now that it’s cold and I’m using the heater. I replaced the manifold gasket and even sprayed it with liquid gasket maker to get it extra tight. I ever replaced the donut gasket and the spring bolts hoping that would solve the problem.
    After reading through the forums it seems like a lot of people have issues with donut gaskets but it hasn’t helped me at all. I’ve looked around the manifold to the cylinder head and see no signs of leaking but it’s starting to make the car throw the p0300, p0301, and p0304 code. I was assuming the misfire came from the leak but I’m thinking the next step would be replacing the gasket at the manifold. It’s driving me crazy bc it just seems like one thing after another. It went months with no issue until it got cold and I started smelling all those fumes.
    please help. Any suggestions are welcomed.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,799
    2017 Prius c
    A visit to a muffler shop that has a good reputation probably would be a good idea.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,966
    1,914
    NJ-USA
    Take it to a repair shop so the entire system can be inspected. Could be anything that was touched- EGR, manifold, donut gasket etc. (I only use OE for the donut and spring bolts) Sometimes I have to fill the system with a smoke machine then pressurize it to find small leaks.
    Unless you have a leak that's close to the air fuel sensor and skewing its readings a bunch, then it shouldn't be related to any misfires.
  4. YYC2015Prius
    YYC2015Prius Junior Member
    Calgary
    Technology
    My mechanic just replaced the front and rear exhaust gaskets and no more exhaust inside cabin and no more fluttering noise when accelerating
  5. Kieron
    Kieron New Member
    Salt Lake City
    Did you solve this issue?
