Why Are People Using Oversized Oil Filters?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Aaron, Mar 14, 2008.
  1. Aaron
    Aaron Member
    260
    Monroe, Ohio
    I've been doing some research on oil filters and came across several posts about Prius owners using oversized oil filters. That came as a huge shock to me.
    Is this practice safe? Wouldn't there be a loss in oil pressure?
    How does it fit?
    Why not use the OE size, but in a K&N or Mobil 1?
  2. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    I think some people feel that having more surface area is better in the longrun. When individual pleats start to clog as the filter ages there will still be more places for the oil to run through. If your filter is all the way clogged it stops filtering and oil bypasses it.
    I agree with your second thought, seems to be way more important to just buy a high quality filter and good oil.
  3. McShemp
    McShemp New Member
    371
    SA, TX
    Go with a quality filter as you suggested, and add Amsoil to that list.
  4. Patrick Wong
    18,200
    6,493
    I'm not among the group that uses the longer Toyota filter, but it is only about 1/2" longer. Additional engine oil is added so that the dipstick level is correct. The fit is the same as the shorter filter. There should be no impact on engine oil pressure.
    Besides increasing available filtration, another motivation for using the longer filter is to make the filter easier to access when removing it, since much of the filter is surrounded by the engine block. This is not an issue for me since I use a cap wrench to remove and install the filter.
    Its not obvious to me that K&N or Mobil 1 filters are better than Toyota-branded oil filters. The Toyota oil filters are available for $3.29 each when buying a case of 10 from Toyota dealers selling discounted parts over the web. See for example:
    http://preview.tinyurl.com/32yw54
    Speaking of K&N, I do not believe that its oiled air filters are suitable for modern fuel-injected vehicles equipped with mass air flow sensors, including Prius. I know a couple of posters who had to have their sensors replaced due to oil contamination. Those filters might be OK if you have an old VW carbureted dune buggy.
    m.wynn likes this.
  5. rudiger
    rudiger Active Member
    696
    45
    Cincinnati, OH
    I like the slightly longer OEM Toyota filter simply because it's a little easier to reach and for the oil filter wrench to get a solid purchase on it.
    The extra filtration surface doesn't hurt matters, either, especially since the longer OEM filter is exactly the same price as the short OEM oil filter that's technically correct for the Prius application.
  6. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    58
    Fullerton CA
    I use the Purolator Pure One PL20195. Compared to the stock filter, it's huge - about twice as long and slightly larger in diameter.
    Why use it?
    1) The Pure One filters are (according to their specs) very good filters and filter down to a very small particle size.
    2) A bigger filter has more filter area and can hold more particulates. I want this since I'm using Mobil 1 Extended Performance 5w-30 and using 10k mile oil changes (if Blackstone Labs says it's OK, I will go to and stick with 15k mile oil changes).
    3) Oil pressure is not an issue - the thing that keeps oil pressure up is the resistance to oil flow of the crank bearings in the engine - not resistance (or lack of it) in the filter.
    4) A subtle point: If you use a bigger filter, then your engine takes 4 quarts - you don't have to worry about 3 and a fraction.
    5) A bigger filter doesn't cost more than a smaller filter.
    6) This filter has an anti-drainback valve as required.
    7) Same threads, same bypass pressure.
    8) The gasket is a bit bigger in diameter, but it still fits well and seats snugly on the filter site.
    You asked, those are my answers.
    Silver Pine Mica and Dino33ca like this.
  7. Aaron
    Aaron Member
    260
    Monroe, Ohio
    Very Nice
  8. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    Four quarts and one filter per year. I could live with that.
  9. uvm1969
    uvm1969 New Member
    39
    Where do you buy these Puralotor Pure One oil filters?
    Thanks,
  10. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I had a 1990 Toyota 4Runner V6, purchased new. In '95 I put on a bunch of Downey parts (Front torsion bars, rear coils, headers, etc). I tried their cone style air filter, which really did help performance compared to how the stock filter sucked in air from around the driver side headlight
    That Toyota had a vane style MAF. Imagine my surprise a couple of years later when the MAF buggered up. The K&N allows just enough oil carryover to clog a vane MAF
    Never again
  11. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
  12. jayman
    13,439
    641
    Winnipeg Manitoba
    Patrick
    Good question. Only way to know for sure is to cut one open
    jay
  13. Patrick Wong
    18,200
    6,493
    The larger filter is 2/3" longer than the correct filter (another member recently sent me the larger filter for evaluation.) Looking inside the filter (without cutting it open), it appears to be fully populated.
    Unlike with consumer products batteries, there's no economic incentive for Toyota to be tricky with the larger filter. The price is the same as the correct filter. Toyota incurs a substantial warranty obligation on the powertrain, and will want its oil filters to do their assigned jobs.
  14. kohnen
    317
    58
    Fullerton CA
    I bought mine at Pep Boys.
    They're not at all uncommon - I am sure that you can get them at almost higher quality auto parts shop.
  15. cariboulou
    cariboulou Junior Member
    Orlando
    can i use these filters on an '08?? i assume i can. How tight do you turn the filters onto the stem?
  16. krg03
    krg03 Not expert, just experienced
    246
    31
    so cal
    I've seen them as well oversized and wondered first if you do a regular oil change/filter, why bother? I change the filter every 5k, add oil and drive on. Synthetic Mobil 1. 15k change oil and filter. It's actually clean at 15k but I realize it breaks down.
    Does a larger filter mean go further between oil changes?
  17. lunacyworks
    lunacyworks Member
    114
    SF Bay Area
    Your only issue is going with a too small filter, a filter that does not filter at the same required level, or a filter that is physically unable to fit or does not create a proper gasket seal. Other than this you will need to make up the amount of oil to accommodate size difference.
    Looks like this thread is from 2010 and I am wondering if there is any update on this?
  18. bisco
    51,155
    after 8 years of research, we figured out that the oem filter works just fine.
    Raytheeagle likes this.
