Why buy wheels?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MaxRabbit, Sep 23, 2011.
  1. MaxRabbit
    MaxRabbit Junior Member
    Near Pittsburgh, PA
    Hi guys, long-time reader here but now I've got a question. After reading a ton of information on winter tires, I see a lot of people talking about getting wheels with their tires. Why do this? Can't you just replace the tires?
    Thanks!
  2. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    It's easier to change to snow tires if all you have to do is remove the non-snow tires on their rims and install the new snow tires on their rims. Anyone with a floor jack can do that easily.
    It also offers less chance to damage the rims by not unmounting/remounting tires twice a year.
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Unless you have a tire stretcher at home, the only way you are going to "switch tires" is to switch the entire wheel + tires.
    If you take it to a tire-shop then yes they can take the tire off and put a new winter tire on. But usually they keep the old tire. Or at a minimum you are left with a bunch of tires with no wheels that you have to bring back to the shop and get them install when the season is over. The shops around here don't want to be spending a bunch of time installing tires they didn't sell.
    That said, I bought a set of wheels and tires for winter. Wheels were only like $80/pc. You can get steelies for half that, but if you are taking a mpg hit with winter tires, might as well put lighter aluminum rims on.
  4. MaxRabbit
    Near Pittsburgh, PA
    Thanks guys. I guess to me I'd rather pay the $40 at the end of the winter to have my old tires put back on. I wouldn't pay that much for new wheels unless I had to.
    But now I get some of the pros to why people choose that. Thanks for the tips!
  5. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    The big deal for me is that fact that your wheels always get damaged when you mount new tires to them. Do this enough times and your wheels will start to look like hell. :)
    Around my area it runs about $70+ to mount and balance.
  6. hill
    8,153
    We got cheesy steel wheels for our studded Montana winter tires (not our Prius - on the AWD hybrid SUV). We go down to Big O, and they swap out the summer tires - and in a few minutes, we're good to go. No need to re-balance with every install. Saves a boat load of time. And the cheesy steel wheels were inexpensive - making their cost a great trade off.
  7. Mendel Leisk
    38,644
    That's the thing: it keeps you tied to the pros, for constant remounting, and rebalancing, likely with a fresh valve every time. And the wear-and-tear. A set of utilitariian steel rims will set you back $50~70 per.
    The parts department at dealer we purchased from gave me some cock-and-bull about the Prius being Toyota's "flagship" vehicle, with no steel rim option. I checked around with several other dealerships, and one finally came through with good advice regarding a compatible Corolla steel rim. They got the business.
    If you're OEM wheels are alloys, switching to snows on steel rims will protect the alloys from winter salt and grit. And gives you an opportunity to detail the rims off the car.
    Basically: if you have a garage/carport, floor jack, safety stands and torque wrench, you can free yourself from the pros. Plus, you can switch tires at your convenience. And if you don't, it's still a lot less hassle: having the pros just swap wheels, vs all the mounting/dismounting.
    It would be worth doing a poll on this to verify, but I suspect the majority of snow tire users have them on extra rims.
  8. fuzzy1
    10,150
    Note that this charge appears twice per winter. And my cars experience winter at lot more than once, more like 15+ times each.
    I delayed getting extra wheels for my Subaru by several years, and the extra tire work caused substantial rim damage and later corrosion. And once, they refused to remount tires that I had planned to use one more season.
    Having extra wheels also means avoiding the day-long waiting lines when a forecast of early snow causes a mad rush to the tire shops.
  9. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    Another item to possibly consider, is that some shops might try to charge for a new TPMS kit each time with the valve stem. This is another $5-8 per tire, also. I asked when I got my new tires & wheels mounted & balanced at the local pepboys. They said they highly recommend (they want the $$) a new kit to be installed each time a tire is removed and a new one mounted on the wheels. Also, in the winter is when you're more likely to slip/slide and be in a inclement weather related accident. I tend to see more curb checks, median hopping, etc in the winter (in one instance, a 90 degree slide, traction, up over the curb and into a ditch was witnessed). There's more potential for wheel damage in winter from those types of circumstances.
    Check out TireRack periodically, too. They'll sometimes run specials where wheels are pretty discounted/discontinued. You can even get tires at the same time, mounted & balanced. Yes, you'll pay shipping, but in the end you might break even on initial purchase if you got wheels too.
  10. MaxRabbit
    Near Pittsburgh, PA
    I appreciate everyone's feedback. I called the local company that everyone in my area recommends, and they use touchless mounting so no damage to the wheels. The first change with new tires are free, too, and from then on it's only $40 including valves and TPMS kits, etc.
    My parents have it routinely done as well and have had no damage. I just might be lucky enough to have a very nice local shop :)
  11. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    "touchless" tire mounting? You have to stretch the tire over the rim somehow.
    $40 isn't bad and if you're happy then good.
  12. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Jedi mind trick?
  13. MaxRabbit
    Near Pittsburgh, PA
    Haha. No, it means that there is no metal on metal contact (unless you were just being sarcastic).
  14. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    I was trying to be funny. :)
