Why did my battery die?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Nov 12, 2016.
  1. Taxi/Limo
    Taxi/Limo Active Member
    509
    107
    Hello All
    I decided to sleep a little in my Prius on a warm day
    I turned turned the car on to engine mode turned on the air con and the radio about a half hour my battery died
    I thought when you turn the car fully on the engine kicks in when battery power is low ?
    Nexus 6 ?
  2. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    It should do that. Are you sure you did? I've left my Prius on READY just as you have and it has worked fine for me.
    Are you saying that the 12V aux battery was the one that died?
    How did you know if it was about 30 minutes if you were asleep?
  3. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    778
    514
    Outside Philly, PA
    Sure you were in READY?
  4. Taxi/Limo
    509
    107
    It could have have asleep longer I think it was the 12 volt batt. I gave it a jump and it started promptly
    I jumped it from the convenient jump terminal under the hood
    Nexus 6 ?
  5. bisco
    49,500
    probably put it in acc.
  6. ILuvMyPriusToo
    778
    514
    Outside Philly, PA
    Not A Climate Controlled . . . :sleep:
  7. Taxi/Limo
    509
    107
    Air conditioning does not work In acc mode
    Nexus 6 ?
  8. fuzzy1
    10,170
    I hope you had it Ready in Park, not Neutral.
  9. Taxi/Limo
    509
    107
    It was in park
    Nexus 6 ?
  10. fuzzy1
    10,170
    When my car is in ACC mode, the ventilation fan and A/C indicator light do come on. The actual A/C compressor should not come on, but my quick test moments ago didn't wait for that, it is too cold here to check that anyway.
    Make sure the 'READY' light is actually on, and/or test that the car will go really into Drive, even if you move the car only inches as part of the test. Then put it back into Park.
  11. Taxi/Limo
    509
    107
    With Acc on the ventilator fan and air condition light do not come on I can do the ready test to see if that splains it
    Nexus 6 ?
  12. Taxi/Limo
    509
    107
    In my 2010 Prius
    Nexus 6 ?
  13. Taxi/Limo
    509
    107
    Jadsiasman. You were right the car was not in the Ready mode thanks for your patience
    Note my 2010 Prius air conditioning does not work nor any component of it does not work In ACC mode
    Nexus 6 ?
  14. ILuvMyPriusToo
    778
    514
    Outside Philly, PA
    So in what mode does the AC work without the engine cycling on?
  15. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    None. In ACC mode the fan works via the 12v battery and if the evaporator core is still cold, chilled air will still come out the vents for awhile and the length of time it stays cool will depend on local conditions (heat & humidity).
    The OP had a failed start. These are usually caused by rushing the start procedure and letting off the brake too quickly.
    fuzzy1 and ILuvMyPriusToo like this.
  16. fuzzy1
    10,170
    Perhaps I misstated, or was unclear.
    Foot off brake, if I press the Power button once, it goes into basic ACC mode. The dashboard remains mostly dark, and the climate control is dead.
    Foot still off brake, if I press Power again, the car goes into another mode where the whole dashboard lights up, and the climate controls go live. Ventilation fan turns on, A/C indicator light can be turned on. But the ignition won't go Ready, the engine won't fire up, neither battery will charge, and I don't believe the A/C compressor can run. This is also the same condition as the 'failed start' fotomoto mentions, when the foot brake is not applied properly during starting.
    CR94 likes this.
  17. bisco
    49,500
    what is the purpose of the second mode?
  18. Taxi/Limo
    509
    107
    I don't consider the second mode an Acc mode but I see what you mean
    Nexus 6 ?
  19. Taxi/Limo
    509
    107
    The air-conditioning works in two and three mode in three mode the engine cycles on and off
    Nexus 6 ?
  20. bisco
    49,500
    wow, a mode that let's you use a/c but doesn't run the ice to recharge the battery? does it give you a warning on the screen?
