Why do Japanese cars have such bad AC?
Discussion in 'Gen 3 Prius Main Forum' started by hayden55, Sep 22, 2017.
  1. hayden55
    hayden55 Member
    115
    48
    This is always a weird one to me. Every Ford, which is mostly what we've owned, in 90 degree weather can get the cabin to about 72 in just a couple minutes. But it seems like every Honda or Toyota we've owned you can crank the AC on full blast and it'll run for 20 minutes before it can finally do it. Then just the fact that the ac always has to run at higher capacity creating more noise that it's domestic counterpart to maintain said temp. So my question is did Toyota design the prius hvac system for a mild Japanese climate because it sure doesn't work well in Arkansas. Will the AC work better if i take it out of ECO mode?
  2. NavyLCDR
    NavyLCDR Active Member
    188
    120
    Stanwood, WA
    The AC definitely works better when not in ECO mode.
    Maarten28 and ShenmueTacos like this.
  3. MelonPrius
    MelonPrius Senior Member
    821
    509
    Las Vegas
    In a word, yes. Take it out of eco mode.
    Maarten28 likes this.
  4. tpenny67
    tpenny67 Active Member
    464
    402
    Massachusetts, USA
    Strange, up here in New England I've found myself wondering why Fords have such an over-sized A/C :)
    jerrymildred, fuzzy1 and CNYhybrid like this.
  5. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    As others have said, yes.
    Eco mode is very aggressive and strives to reduce the a/c load on the system because the compressor is electrically powered and will use up a lot of the battery which; therefor, needs to be recharged by the gasoline engine thus lowering fuel economy. In the south, it's best not to use ECO during the summer (or at least during the hottest parts of the day). Also, use recirc to avoid trying to cool a constant stream of fresh but hot outside air.
    My Ford Energi doesn't have an ECO mode but during the summer the a/c can feel weak when set to auto mode because that setting is too aggressive in reducing fan speeds. Max a/c (60f and 5 of 5 fan speeds) will cool the car quickly but that setting can reach as high as 3.5-4 kwH which is a lot so I can understand their reasoning.
  6. ChapmanF
    15,573
    There's a lot that I like about my Gen 3's A/C. I find it usually does a very nice job of modulating the compressor and fan so I just feel steadily comfortable without feeling blasted, and most days I keep ECO on, but I'll admit that today (and days like it) I turn ECO off....
    2010 and 2011 also seemed to come with this vaguely-described ion plasma generator in the driver's side A/C duct. I don't know how much effect it has (and I've never tried unplugging it to see if I notice any difference), but the air usually does seem pretty sweet in the car and my allergy symptoms often seem to scale back when I'm in it. But it seemed to get discontinued in the 2012 refresh.
    -Chap
  7. 3PriusMike
    2,967
    2,317
    Silicon Valley
    Seems that it would have been reasonable to try this if you had a problem in the first place and thought to ask the question.
    Anyway...when my car is hot I always open the windows for a couple of minutes before turning on the A/C, if I intend to use the A/C. Why cool off a bunch of air that you can more easily force out of the car?
    Mike
    Prodigyplace likes this.
  8. BZzap!
    BZzap! Senior Member
    1,607
    877
    I always purge the hot air out of the interior by rolling down the windows. It only takes a minute or so.
    BTW, the A/C in my Prius stands among the best systems I've had in any car previously owned. This is probably due in large because of the tinted windows...especially the (near) horizontal back glass. I have install the window tint in a very dark to lighter from rear to front. The rear hatch glass is dark limo tint.
  9. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    I was soo expecting an off color joke according to title of post.
  10. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    I think the Prius' AC works pretty well in the summer and I live in North Carolina! Loud, yes, but it's plenty cold. My mother-in-law's RX450h's AC is pretty cold too especially when you turn the ventilated seat to full blast...and very quiet too even at full blast.
    The heat is lacking though, IMHO. I was spoiled by my old '06 Honda Accord's system because I'd get heat within 2 minutes even when the engine was stone cold and 20 degrees outside. My Prius requires at least 5 minutes to bring some hot air in the cabin.
  11. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Can't speak for other versions, but having both a 2010 and 2015 Prius, the A/C is not even close to good enough for Texas summers.
  12. Maarten28
    Maarten28 Active Member
    414
    224
    Netherlands
    Yes it will, and it even says so in the manual. The airco will be less effective and the highest fan speed will be lower when in ECO mode.
  13. hayden55
    hayden55 Member
    115
    48
    I've noticed it takes about 3% ac load to drop the cabin temp a degree in sunny weather. Any of you window tint guys notice a difference? For reference we have a couple 110 degree days every summer and probably average 100 (even now it's 95-100). the AC never kicks off full blast at 110 .
  14. hayden55
    hayden55 Member
    115
    48
  15. BZzap!
    1,607
    877
    In regards to window tint, see #8 post
  16. Bluegrassman
    Bluegrassman Active Member
    229
    185
    US
    It's been my experience that over 3 decades of owning vehicles made by just about every major car maker, my Toyota/Lexus cars and trucks have consistently had the best A/C systems of anything I've owned.
    With my Prius, when it is extremely hot and sunny days when the car has been cooking out in the sun, I will turn off ECO mode, but only for the initial car cool down. After that, back to ECO and all is well.
    Working fine in eco with out 90+ degree sunny days
  17. mikefocke
    3,698
    1,645
    Sanford, NC
    I guess I'm the only one who keeps the ECO on summer (to 100F) and winter (to 15F). Obviously I do vary the a/c and temps but in the summer it is ECO, recirc, a/c, 74 and forget it. Somehow spending summers in a steel hulled ship in the south made me a little more tolerant of heat than you guys. Not to mention the interior of a v is larger than the hatchbacks. White exterior, parked mostly under cover.
  18. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    I guess I'm just old school.
    Since I remember a time when a considerable amount of cars did not have AC period. And AC was considered a luxury item.
    So while perhaps the Honda Fit (Made in Japan) doesn't have the strongest or quickest to cool AC, I'm perfectly OK with it. It does work for me, in my climate.
    By the way, I felt the Prius climate control system worked great. I was never lacking for whatever I needed with it.
    #18 The Electric Me, Sep 27, 2017
    Merkey likes this.
  19. everdave
    everdave New Member
    Earth
    2015 Prius c
    I always am pleasantly surprised by how cold and fast the car gets cooled down any time I drive my wife's C. The AC works amazingly well even in 90+ degree heat.
  20. vForVictory
    vForVictory Junior Member
    29
    East Bay, CA
    Our only complaint about our new Prius v is how LOUD the A/C is. We actually wish it wasn't as aggressive in cooling the car (at least the fan part) so that it wouldn't be so loud, and in fact we sometimes take manual control of it to reduce the fan noise.
    But apart from the noise, we think it's great!
    However, our previous car - a 1997 Honda CRV, had the worst A/C of any car I've ever owned, despite sinking in way too much money into it over the years. Prius A/C is far, far better. We had a heat wave that included two 110 degree days in a row and it was fine (but very loud!).
