Why do my wheels turn bronze-colored? Brake dust?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kevelev, Jun 27, 2018.
  1. kevelev
    kevelev Junior Member
    65
    ny
    2011 Prius (Base model, non plug-in). Why do my wheels start turning this color? Is it brake dust? The residue was on the outside of all 4 wheels as well but I scrubbed it off. I had to use a rough scrubber to remove it because wheel cleaner didn't do anything. 20180624_170627.jpg
    52,354
    affirmative. how many miles on her? are the pads holding up well?
    not sure about the inside, but my outsides are pretty clean after 60k. maybe pads are rubbing too much.
  3. kevelev
    65
    ny
    Yes the pads are holding up well. There are at least 40,000 miles on the pads. I'd say there is still 3/4 life left in them. I recently replaced a wheel bearing in the front and cleaned and re-lubed all the front brakes. The car has about 105,000 miles, but I don't know how many were on the brakes before I got the car from the dealer.
  4. Mendel Leisk
    41,865
    How many miles on it? That sort of looks "baked on". Glossy-bronze appearance is odd. Feel all the wheels after an extended drive, see if any feel hot?
  5. ASRDogman
    ASRDogman Senior Member
    7,794
    3,976
    That is the brake pad material. Try using gunk on it. Or brake cleaner, but that's expensive, but effective.
  6. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    What is the point of cleaning this unseen part of the wheel? Doesn't the gunk actually protect the metal a little?
  7. ASRDogman
    7,794
    3,976
    Gunk is a cleaner. Unless you get that crappy foammy stuff. What a waste.
    I don't see how it would protect anything. Gunk, use a brush if you need to, then rinse with water.
  8. Mendel Leisk
    41,865
    Not sure, that looks so glossy, like it's baked:
    And even in the hub zone?
  9. Mendel Leisk
    41,865
    Shot of ours:
    (Fronts look similar.)
  10. kenoarto
    398
    Chicago, IL
    LOL! Ya I was using the term "gunk" in its original definition of "dirt". I hate when corporations confuse our language:
    Gunk | Definition of Gunk by Merriam-Webster
    bisco and Mendel Leisk like this.
  11. ASRDogman
    7,794
    3,976
    Okay! :) :) it was all gunked up!
  12. kevelev
    65
    ny
    The glossiness is because the photo was taken right after i hosed it off. The hub zone is the result of not using anti-seize between the steel hub and the aluminum wheel.
  13. kevelev
    65
    ny
    You're right. I don't need to clean it, but the same thing will happen on the outside of the wheel, and that I DO care about. I was just surprised how hard it was to clean. I had to scrub every little spot with a Scotchbrite pad. But I can try the other cleaners mentioned.
  14. kevelev
    65
    ny
    What I don't understand is why it's a sticky residue. Most brake dust I've seen is just that - dust. This is like a thin film that is stuck on.
  15. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    Could of it be something that was on the road that you ran through?
    Oil patch? Accident scene remnants before absorbent material could be applied?
    Once the sticky material is there, could dust, dirt or some other particulate be adhered (maybe even brake dust?
  16. Mendel Leisk
    41,865
    To argue with myself: I was doing the brakes on a Pilot, and the inside of the rims looked somewhat similar. Maybe heat bakes the brake dust somehow?
  17. kevelev
    65
    ny
    Possibly, I'm gonna monitor it and see if it comes back on the cleaned areas.
    Raytheeagle likes this.
  18. ASRDogman
    7,794
    3,976
    Think of this, the inside of the wheel is a cavity, it will collect water, dirt, grime, and anything else.
    The rotor spins throwing the brake pad dust against the inside of the rim. Some gets thrown on the outer
    section of the rim but you have a steady flow of air blowing it way so it won't be as bad. Notice other vehicles
    that will have dirty front rims.
  19. padroo
    padroo Senior Member
    2,763
    2,252
    You don't drive on those famous NY dirt roads do you. I heard they use salt on those roads year round.
    Prius rotors will rust overnight and clean off with a few brake applications, my guess is rust and brake dust.
  20. kevelev
    65
    ny
    Yes, I drive in upstate NY. They do use salt, but only in the winter, lol. I haven't noticed them getting worse since I cleaned them off in the spring, so maybe it is from the salt.
