Why do some newer Priuses have gas tank on left and some on right
Discussion in 'Gen 3 Prius Main Forum' started by lintriago, Apr 9, 2015.
  1. lintriago
    lintriago Junior Member
    23
    Sonoma, CA
    I
    I recently updated to a 2015 Prius. My last Prius had the gas tank on the passenger side. This one has it on the driver side. From what I've read all 3rd Generation Priuses have round gas tank doors on the drivers side. I have noticed a few (definitely) a minority, that have the gas tank on the right side.
    Just curious as to why this is? Anyone know?
    51,155
    never seen one on the passenger side, you're probably looking at the pip plug in charging port. was your last prius the 2001 in your profile? that might explain it.
  3. lintriago
    23
    Sonoma, CA
    I
    Well it looks exactly like my gas tank only it's on the right side...
    51,155
    yes, the door is similar.
  5. mrbigh
    3,686
    699
    Long Island, NY
    I Never realized that where a USA issue Prius with a gasoline refueling door on the passenger side.
  6. wjtracy
    wjtracy Senior Member
    11,361
    3,606
    Northern VA (NoVA)
    ...the only thing I can think of is changes for crash test ratings, but I remain confused if we have a confirmed finding of a design change yet
    If OP got himself a PiP, be sure to get Green HOV sticker while they're hot and CA rebate
  7. fuzzy1
    10,335
    On those particular cars, have you looked closer to be certain the door is only on the right, nothing on the left?
    The Plug-In Prius has two round doors, gas tank on the left, electron tank on the right.
  8. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    A quick way to tell a Plug-in model is that they have brushed metal (stainless steel?) trom along the lower edge of the rear hatch.
  9. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    There are several "tells" for a plugin Prius. The "bar" just under the lower rear window and the door handles are silver-gray instead of body color. The outer inverted 'J' of the tail lights have clear lenses instead of red. The HSD logo includes a silver plug. A 'bar' just above the lower grill is silver instead of black. The label on the front fenders has two lines to read Plug-in Prius. And of course the "fuel" door on the right, which also has a plug logo on it.
  10. bisco
    51,155
    i moved the charger to the front on mine, because my evse wouldn't reach the back right corner unless i backed in. since the door was already there, i added a second gas tank.
  11. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    I converted the charging port on my car to a Mr. Fusion home energy reactor since 3 kWh seems kinda piddly compared to 1.21 gigawatts.
    pilotgrrl, bisco, DAWg134 and 2 others like this.
  12. bisco
    51,155
    nice.(y)'m gonna do a write up, as soon as i learn how to post pics from my polaroid.
    paprius4030 and Redpoint5 like this.
  13. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I think they're all in the same place regardless of market. Mine is a RHD car and the refueling door is on the passenger side - your driver side.
  14. mrbigh
    3,686
    699
    Long Island, NY
    (y)
  15. Jamieconway
    Jamieconway New Member
    UK
    My Toyota Prius 2011 imported from Japan has the gasoline refueling door on the passenger side - the left side.
  16. bisco
    51,155
    welcome!
    mine has the charging port on the starboard side.
    padroo likes this.
  17. bisco
    51,155
    i wonder if o/p was to embarrassed to come back and restate his position.(n)
  18. Tideland Prius
    16,445
    Yes, it's in the same place as ours.
    I think the OP saw PiPs with their EV charging connector on the right side.
    Jamieconway likes this.
  19. padroo
    padroo Senior Member
    2,763
    2,251
    Wow, shows how observant I am, I don't ever remember even seeing a plug in except at the auto show.
    I know a Prime when I see one.
  20. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    The Japanese passanger side is the driver's side in the US (and almost all other countries). My gasoline refueling door therefore is on the driver's side - the left side.
    No need to overcomplicate things by stating where the passenger sits, the gasoline refueling door is always on the left side.
    Jamieconway and bisco like this.
