Why do some Prius v's (lowercase v for the Prius v wagon) have black fronts?
Discussion in 'Prius v Main Forum' started by Mike Moon, Dec 11, 2016.
  1. Mike Moon
    Mike Moon Member
    31
    48
    Marietta, GA
    Four Touring
    Why do some Prius v have black fronts (For the bottom half of the grill) and not others? I have a Prius v model 5 and my front end is all painted the same color as the car. But I don't see as many like that as the ones with partially-black grills.
    #1 Mike Moon, Dec 11, 2016
  2. Tideland Prius
    16,560
    2012-2014 had colour-keyed front bumper and grille
    2015-current have the black plastic insert. I haven't seen a 2015+ model without the black plastic insert. Could yours have been painted aftermarket?
    Prodigyplace likes this.
  3. Mike Moon
    Mike Moon Member
    31
    48
    Marietta, GA
    Four Touring
    Maybe... I don't know. I bought it new from the dealer. It's a 2015. Here's a photo...
    #3 Mike Moon, Dec 15, 2016
    GregC1979 likes this.
  4. Tideland Prius
    16,560
    Yes, that looks correct. That is the midlife update bumper for 2015-current Prius v. The 2015-current Prius v also have revised taillights. They have the 2 horizontal bars as taillights with brakelights built in behind it. The 2012-2014 Prius v have vertical taillights with somewhat visible LED bulbs.
    This is the front bumper for a 2012 to 2014 Prius v. In this photo, this is a Prius v Five with AT package. It has LED headlights, 17" alloys and the optional panoramic resin moonroof.
  5. FBear
    FBear Senior Member
    355
    23
    Maplewood, NJ
    2015 Prius v wagon
    That insert in the bumper makes the 2015 pass the offset crash test with a good rating
  6. Norcal2
    Norcal2 Junior Member
    23
    Sacramento
    2015 Prius v wagon
    My 2015 has the grey inserts, perhaps its the trim package that you have mine is 5..
  7. GregC1979
    GregC1979 Active Member
    201
    121
    Nowhere
    Is there any mileage difference with 14-15 year models with update in body style?
  8. Prodigyplace
    12,585
    11,791
    Central Virginia
    2015 and newer have better crash test ratings.
  9. Tideland Prius
    16,560
    If any, it'll be small. I don't think Toyota sent it in to be rated again since it's the same engine and falls within the same weight range. They updated the Prius c's rating for 2017 (slight update in EPA method) but I can't remember if they updated the Prius v as well. Basically it will result in a lower published mpg but keep in mind it's due to the change in EPA method.
  10. GregC1979
    201
    121
    Nowhere
    So getting over 44 mpg city is easily possible in the v?
  11. Tideland Prius
    16,560
    I really don't know Placentia so I can't comment on how easy it is. I got 52mpg on a short test drive near Toyota HQ at the pre-launch but that's rare.
    I would expect 40mpg city and if you get higher, then you'll be happy, rather than expecting over 44 and possibly getting lower.
  12. GregC1979
    201
    121
    Nowhere
    It's slightly downhill to work 6 miles each way, slightly uphill very gradual back home. Weekends, 10% highway. Toyota HQ in Torrance California is where you tested?
  13. Prodigyplace
    12,585
    11,791
    Central Virginia
    They had it rated again. The overlap tests went from poor to good. 2014 is poor and 2015+ is good.
  14. Tideland Prius
    16,560
    Yes. Oops I lied. It was 50mpg, not 52. Sorry.
    If it's light traffic and long blocks, you should be able to get over 44mpg then.
    I was talking about FE rating, not crash ratings.
    GregC1979 and Prodigyplace like this.
  15. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    I don't like the black front insert on 2015+ ...I would like to be same color of car as per OP
    If I could fix that I might get one
  16. mikefocke
    4,011
    1,814
    Sanford, NC
    By now there are enough entries on fuelly.com that you can get a good idea of what real people in mixed situations get from a car. There are about a dozen v wagons in my development and no one drives them using any special techniques that I've seen. My mileage is probably ~30% short trips miles (but 90% of the trips) and ~70% 60-70 MPH highway.
  17. RAM v
    RAM v Junior Member
    72
    St. Paul, MN
    2014 Prius v wagon
    My average for my last 10 tankfulls is 53.5 MPG. Most of that was probably 75% or more city driving.
  18. GregC1979
    201
    121
    Nowhere
    What are your tire pressures set at? Do you drive in Eco or Power mostly? Light or medium throttle?
  19. RAM v
    RAM v Junior Member
    72
    St. Paul, MN
    2014 Prius v wagon
    Tire pressures are 38-39. I drive exclusively in Eco mode. Generally light throttle although I have been pleasantly surprised by the power when it comes to freeway entrance ramp acceleration and passing power. I also tend to choose my routes to maximize economy.
