WHY DOES MY 2006 PRIUS RADIO CUT OUT AFTER ABOUT 5 MINS WHEN STATIONARY
Discussion in 'Gen 2 Prius Audio and Electronics' started by alan forshaw, Feb 14, 2020.
  1. alan forshaw
    alan forshaw New Member
    UK
    THE BATTERY IS GOOD BUT THE RADIO CUTS OUT AFTER ABOUT 5 MINUTES OF BEING STATIONARY - I HAVE TO TURN ON THE ENGINE TO BRING THE RADIO ON AGAIN?
  2. valde3
    valde3 Senior Member
    2,002
    748
    Finland
    In ready or in ACC?
    If it's in ready and stationary. So radio operation some how linked to engine? Maybe it could be a bad connection somewhere? And it changes when car shakes with engine idling.
    You have no fault lights or codes?
    If it's only in ACC. How did you check that 12v battery is good? Depending on method maybe you have a bad connection or a bad battery. Meansure the voltage at jump start terminal when the radio is working. Is the voltage dropping before radio shuts down?
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
    If you're listening to it in ACC or ON ,,, STOP THAT! ;)
    Seriously, that's a really bad idea in a Prius. Keep the car in READY mode if you're going to listen to the radio. That dinky 12V aux battery is not like the one in your neighbor's diesel F350. It's just made to fire up some computers and close a couple relays. As a result, newer models of Prius will shut off after a few minutes in ACC or ON to protect the aux battery.
    kenoarto likes this.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    THIS.
    It is designed to do exactly what he is seeing.
  5. ETC(SS)
    7,094
  6. AzWxGuy
    AzWxGuy Weather Guy
    1,048
    532
    Tucson, AZ
    2021 Prius
    I see it's a UK shreadout. Will a 2006 model across the pond have this? My 2008 USA brand would run that 12V flat if given half a chance.
    #6 AzWxGuy, Feb 16, 2020
