Why does my 2008 Prius get 3-4 mpg better mileage than my 2004?
Discussion in 'Gen 2 Prius Technical Discussion' started by pjongbloed, Nov 7, 2018.
  1. pjongbloed
    pjongbloed Junior Member
    Why does my 2008 Prius get 3-4 mpg better mileage than my 2004? Both have the same tires installed at the same time and are inflated to the same pressure. The 2008 also coasts further and feels stronger when driven with the motor.
  2. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    655
    262
    Dodge Co. Wisconsin
    2017 Prius v wagon
    Fresher battery pack?
    Has the (Tranny) oil been changed?
    48,988
    there are so many little things on a prius that can affect mpg's. how many miles on each?
    Raytheeagle and The Electric Me like this.
  4. pjongbloed
    Has had all normal services.
  5. pjongbloed
    04 has 142,000. 08 has 125,000. Had the 04 diagnosed but nothing was found. The coasting distance difference leads me to believe that that is causing the mileage difference. Did talk to another Gen 2 Prius owner who said the 08's had a software upgrade. That I have not confirmed.
  6. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    Lots of possibilities!
    For years, I maintained high speed automated 200 ton presses (625 strokes per minute). We had a row of five "identical" presses. Every one of them behaved differently.
  7. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    You could swap battery packs between those 2 cars to see if that’s the difference. Plus doesn’t the 2008 have better battery’s to begin with?
  8. bisco
    48,988
    i had an '04 and an '08, didn't notice any difference in mpg's.
    if you think there is drag, pull the wheels, inspect the brakes, hubs, bearings and etc.
  9. 05PreeUs
    05PreeUs Senior Member
    1,097
    563
    MSP
    The '08 is 4 years newer?
  10. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,783
    2017 Prius c
    So many in fact that this really is not a reasonable question.
    One could substitute ANY make of car for the Prius's in his question......and the answer would be equally as elusive.
    The answer: Because they are not the same car.
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    Pretty easy to figure out.
    If the hybrid battery is original in the 2004 and still working good it would be a miracle.
    A Prius is only as good as the hybrid battery. If the battery is not contributing alot of power then the bulk of the power demand falls on the anemic little 90 horsepower motor.
    Signs of early retirement are the hybrid battery goes to purple bars real fast like in a fast food pickup lane and once it has purple bars it will not recover to blue bars very well.
  12. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    I agree with everyone here.
    Basically you're only looking at two factors here, actual age of the vehicle and tires/tire pressure.
    And there are so many other factors that can make a difference.
    Really, it comes down to how satisfied or unsatisfied you may or may not be with your 2004's performance. That is now a 14 year old vehicle so what could cause a difference becomes hard to pinpoint.
    Could be aged Hybrid Battery.
    Or could be the operational decline that comes with any machine that has been in service for 14 years.
    Or the combination of both.
  13. padroo
    padroo Senior Member
    2,763
    2,250
    Software came to mind. I new a guy who had two 2008 and the newer one didn't get the mpg the first one did.
    I don't remember the numbers he quoted.
  14. bisco
    48,988
    some people are mistaken about that because the epaulet changed the testing protocol between the two years and the monroney numbers changed, but not the car
  15. frankv64
    frankv64 Junior Member
    23
    Colonia NJ
    Does someone else drive the cars other than you? That could also be the reason
  16. Mendel Leisk
    38,247
    So transaxle fluid change likely hasn't been changed.
    Probably neither here 'nor there; just for the record.
    I agree with that.
    #16 Mendel Leisk, Nov 21, 2018
