Why does my key fob not work first thing in morning?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Joe Wall, Aug 15, 2021.
  1. Joe Wall
    Joe Wall Member
    213
    42
    Wisconsin
    After working out within range my key fob wont unlock. It is always the first time i use it in the morning. I try unlock and lock at least 10-20 times then use the manual key. The rest of day it works just baffles me why this is occuring.
  2. dolj
    dolj Senior Member
    7,645
    3,858
    Wellington, New Zealand
    How is the CR2032 button battery in the fob?
    What is the voltage of the 12 V battery in the right rear first thing in the morning?
  3. archae86
    archae86 Member
    153
    24
    Albuquerque, NM
    When the original 12V battery in our Prius began to age, fob reception problems were one of the symptoms. The fact you are seeing trouble first thing in the morning somewhat fits a 12 V problem, as overnight the battery voltage will have dropped down a bit.
    If that is really the case, probably things will get worse when it gets colder.
    Mendel Leisk and bisco like this.
  4. Joe Wall
    Joe Wall Member
    213
    42
    Wisconsin
    Ill check the voltage in the morning and let you know. Thanks!
  5. Joe Wall
    Joe Wall Member
    213
    42
    Wisconsin
    I bought it used and had something dine with 12v battery. Id have to check the service history when get home.
  6. ColoradoBoo
    ColoradoBoo Senior Member
    963
    630
    Monument, Colorado USA
    When you walk up to the car with the fob, does the red light on the fob come on? This indicates that the fob detects the car and is active so if the red light does come on, it's a problem with the car system, not the fob.
    How old is the 12 volt battery? I've heard that many (most?) strange electrical problems start with the 12-volt battery going out.
  7. Joe Wall
    Joe Wall Member
    213
    42
    Wisconsin
    The lights showing mph and etc dim out if i keep lights on as well. Then i turn them off. Think the dimming if from battery as you mentioned
  8. fuzzy1
    10,167
    This part should have nothing to do with the battery, if you are testing while the car is READY and running. When READY, the 12V system is powered and regulated by an inverter from the traction battery. This is the Prius version of the alternator & voltage regulator of a traditional car.
    There is a scroll wheel brightness adjustment to control if, and how much, the dashboard lights dim at night when the headlights are turned on. If you don't want them to dim, e.g. when using the headlights in daytime, roll that adjustment wheel all the way up, then 'clicks'.
    edthefox5 likes this.
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    Measure the 12 volt battery with engine off first thing in the am before starting the car.
    Measure it at the front jump under the hood with car off. It is useless to measure it directly.
    If your not close friends with the 12 it probably has a corroded ground connection too. This can be detected by measuring at the front jump point. Then measure directly at the battery. If more than exactly .5 volts less at front JP there is a connection/corrosion issue in the hatch.
    12 volt battery is probably sitting in water too. Very leaky back there.
  10. bisco
    49,444
    post #3 nailed it
  11. Joe Wall
    Joe Wall Member
    213
    42
    Wisconsin
    Red light does come on
  12. bisco
    49,444
    what was the 12v reading?
    how old is it?
  13. Joe Wall
    Joe Wall Member
    213
    42
    Wisconsin
    Will get reading tmrw or next day
  14. Joe Wall
    Joe Wall Member
    213
    42
    Wisconsin
    Gonna do a load test today and can test tmrw morning
    Colorado Boo likes this.
  15. Joe Wall
    Joe Wall Member
    213
    42
    Wisconsin
    Weird load test says 100%.
  16. Joe Wall
    Joe Wall Member
    213
    42
    Wisconsin
    Red light was on tho ocassionally
  17. Joe Wall
    Joe Wall Member
    213
    42
    Wisconsin
    Key fob was dead lol.
  18. bisco
    49,444
    was that the problem?
    what load tester? did it show voltages?
  19. bisco
    49,444
    does it?
  20. Joe Wall
    Joe Wall Member
    213
    42
    Wisconsin
    Fob key battery was dead. Load test was 100% for battety. Kind of a pain to access the battery.
    donbright likes this.
