Why does my PiP beep at me when I leave?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by plugable, Apr 9, 2012.
  1. plugable
    plugable Junior Member
    59
    Rancho Cordova, CA
    When I open my driver side door to leave my PiP right after I shut it off, it beeps at me about 6 times. If I wait about 8 seconds or so before opening the door, it doesn't beep. If I wait in between 0 and 8 seconds, it beeps at me a number of times inversely related to how long I wait - the longer I wait, the less times it beeps. Has any body else noticed this? :confused:
  2. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    Not a PIP owner so I'm not sure about your number of beeps but in a regular Prius a three beep code means you left the car on (ready mode) and exited with the key fob.
  3. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    Obviously, it enjoys a few seconds of quiet time with you!:D
  4. plugable
    59
    Rancho Cordova, CA
    Well, this is my 3rd Prius, and I'm hitting the "Power" button each time to shut it off like I always have. I did notice that the 8 second delay before I can open the door without it beeping does seem to correspond with the interior light coming on by itself.
  5. plugable
    59
    Rancho Cordova, CA
    Psychologically speaking, it does seem to either have control issues, or it's just being needy....:)
  6. Jaquimo
    Jaquimo Paraglider, Prius glider...
    96
    38
    Bloemfontein, South Africa
    I think it may be a little insecure and does not want you to leave. I also think that the longer you take to open the door before leaving the less insecure it feels and therefore it beeps fewer times. But since I have never observed such behaviour myself I have to rely on guesswork for now. I beg you to please share with us any additional information that you might discover which may lead to such strange behaviour since one of us other PC fellows might just end up with such a case ourselves one day.
  7. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    There may be a setting that can be changed. Since this is your 3rd. Prius, have you tried to check the 12V SOC on the diagnostic screen?:cheer2::cheer2:
  8. plugable
    59
    Rancho Cordova, CA
    12V SOC's? Isn't that what you use to keep your feet warm in the winter? :) But seriously, since my Prii have been so reliable, I haven't felt the need to get too involved with their inner workings. I did buy a scangauge a few years ago, and I've used it a couple of times to get rid of the reverse and seat belt beeping, but that's about it. But if you don't mind telling me what to look for and how to look for it, I'd be happy to give it a try.:rockon:
  9. RolfS
    RolfS Junior Member
    45
    I have no idea. There should be a Warning Message along with any buzzer. Look at pages 556 to 561 (the pink section) in your manual. Maybe one of those will make sense to your situation.
  10. andyprius
    2,212
    188
    This was a common procedure on the previous generations, but like they say, if one is not aware of a problem, there is no problem!
  11. ukr2
    ukr2 Senior Member
    1,009
    275
    31
    Victor, NY
    Plugable,
    I haven't noticed the beeps when leaving the PIP, but I will be listening tomorrow.
  12. andyprius
    2,212
    188
    Come to think of it, that is the warning the car gives when you leave it in ready and step out of the car. Also, I have never tried it, but the same warning may go off if you leave the FOB in or around the car. Do you know the whereabouts of your other FOB?
  13. plugable
    59
    Rancho Cordova, CA
    There is no Warning Message, but when I look at the Customization section of the manual, I notice a couple of interesting things. Under "Operation after the POWER switch turned off", the default is "ON", and the Customized setting is "OFF". When I hit the POWER switch to shut off the Prius, the overhead lights come on after a delay of about 8 seconds. That corresponds to the time I need to wait if I want to open the door without it beeping at me. Does your overhead light come on right away after you hit the POWER button? Also, it says I can change the setting using the navigation system. Do you know how I can do that? I can hit the "Setup" button to the right of the MFD, and then hit the "Vehicle" soft key, but I don't see where I can change the setting there.
    Another thing I noticed was that the overhead lights don't go on when I approach the car with the key in my pocket. The default setting is supposed to be "ON", and it says I can configure it through the navigation system, but I haven't been able to figure out how. Any assistance would be appreciated! :)
  14. plugable
    59
    Rancho Cordova, CA
    The other fob is inside my house. I think the problem is associated with the Customization settings. Please see my response to RolfS for more info.
  15. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    As soon as I hit the Power button, my interior lights come on.
    There are 3 types of customization that can be done: via the Display Audio Unit, via the Premium HDD Nav unit, and via the Dealer. It sounds like you are referring to one that can only be set via the Premium unit or via the Dealer.
    This is an option that only your dealer needs can set. It can't be set by either the Display Audio or Premium Nav unit, unfortunately.
  16. plugable
    59
    Rancho Cordova, CA
    Thanks for the info! It sounds like I'll need to schedule a visit with the dealer. Since the options are configured differently than the default settings, I would assume they will cover it under warranty.
  17. CharlesH
    2,785
    1,152
    Roseville, CA
    If it is the dealer where you bought the car, you may be able to talk them into doing it for free, like was done for me for to change the <bleep> continuous backup alert to a single beep.
  18. ukr2
    ukr2 Senior Member
    1,009
    275
    31
    Victor, NY
    I brought my PIP to the Dealer Monday, 26 days after purchase, and they had no problem changing the opening of the Driver door to also unlock the other doors. FREE.
  19. devprius
    devprius /dev/geek
    979
    291
    There's a procedure in the manual to do that. No need for a trip to the dealer. Though it is nice of them to do it for free.
  20. hsnyder
    hsnyder Junior Member
    44
    I too am experiencing this "one or more short beeps after powering off and opening driver door." It started at about 10k miles on my Prius v, a month ago or so. Hadn't changed a thing.
    • No extra fob in car.
    • Auto-off feature takes care of lights so it's not that.
    • And I don't have a sunroof.
    • And it's not like I'm even opening the door *while* I'm powering down ... there's a good second or two between releasing the power button and opening the door.
    I thought it might be because my maintenance light had just come on for the 10K service and it was an added reminder (?), but that's out now and it's still doing it.
    As far as leaving it in Drive, I never put it in Park before powering off (so is transmission really still in Drive?). My Prii have never fussed at me before for doing this.
    Been a Prius driver for 10 years and this is my 3rd. Never experienced this before and just ...
    ... baffled.
