Why does my Prius tell me when it's 37 degress?
Discussion in 'Gen 2 Prius Main Forum' started by Atreides, Mar 1, 2007.
  1. Atreides
    Atreides New Member
    17
    It's getting a little cold out here in Sonoma County and for some reason my Prius' computer has a pop up for when it reaches 37degrees outside. Can anyone explain this to me?
  2. Soylent
    Soylent The v isn't a station wagon! It's just big boned
    443
    Fort Lauderdale, Florida
    2013 Prius v wagon
    Maybe to warn you that the roads may be icy?
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,999
    Fort Lee, NJ
    Watch out for the black ice.
  4. Tideland Prius
    16,220
    what seawolf said.
    at 37, there may be black ice esp. if it's sunny and there are shaded areas. The sunny weather lulls you to a false sense of security that it's warm and dry and above zero means that ice has melted.
  5. ohgreys
    ohgreys New Member
    123
    I've never been able to figure it out. At least if the message came up when it hit 32 degrees I would know that it was telling me that it was freezing. But 37 degrees?
  6. Tideland Prius
    16,220
    <div class='quotetop'>QUOTE(ohgreys @ Mar 1 2007, 12:13 PM) [snapback]398653[/snapback]</div>
    did you not read what we said? lol.
    It isn't limited to the Prius. Some other vehicles do have this warning.
  7. kdailey356
    kdailey356 New Member
    111
    In my '07 328xi there is like a AOL Instant Message noise when starting the car and a snowflake, on my land rover it just beeps and the prius has a nice little pop up... all for the same reasons:)
  8. iaowings
    iaowings New Member
    450
    Again it is possible when the ambient temps are at 37 degrees Fahrenheit that in the shade and other place for the temps to drop low enough to form ice. My last two cars did this as well.
  9. FarmGeek
    FarmGeek New Member
    As far as I'm concerned, I can't rely on the outside temperature reading. Its usually 4-6 degrees high.
    So 37 degree reading is really somewhere around 32 degrees.
    This is one area Toyota really messed up on. How can I rely on the mileage calculations, etc. if they can't get the thermometer right?
  10. cireecnop1
    cireecnop1 New Member
    338
    Pueblo, CO
    <div class='quotetop'>QUOTE(Tideland Prius @ Mar 1 2007, 01:11 PM) [snapback]398651[/snapback]</div>
    It would be nice if it was more like the Audi A4, it have a large snowflake in the spot that the degrees use to be, just to remind you. instead of popping up then disappearing after a second
  11. Stringmike
    Stringmike New Member
    77
    Probably because the factory conservatively decided to warn you when the temperature got to within 3 degrees Celsius above freezing - that's pretty close to 37 degrees F.
    Mike
  12. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(Atreides @ Mar 1 2007, 01:59 PM) [snapback]398606[/snapback]</div>
    My old Volvo turned on a red LED when it was 35 or lower. The Prius seems not quite so distracting.
  13. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    It's in the owners manual:
    Snowflake: Overpasses and bridges may become icy.
    since they chill with the wind and not the insulated ground, they may freeze first.
    <div class='quotetop'>QUOTE(TomorrowMatters @ Mar 1 2007, 03:26 PM) [snapback]398704[/snapback]</div>
    You're 2007 doesn't have the dash snowflake. They took it out in 06? my 04 has a yellow flake on the dash. It's right next to the "lights on" indicator. It stays on as long as the car stays below 37. Some find it annoying because it's bright.
  14. usbseawolf2000
    14,487
    2,999
    Fort Lee, NJ
    Since 06 (high resolution MFD), there is a message come down like a pull down menu. No more snow icon light.
  15. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    <div class='quotetop'>QUOTE(FarmGeek @ Mar 1 2007, 03:49 PM) [snapback]398683[/snapback]</div>
    If you block your grill enough the reading will be even more inaccurate. On some tanks I have a variance of 20% between the MFD and my calculations for mpg. The only indicator I completely trust is the flashing pip.
  16. Texas911
    Texas911 Member
    405
    Houston, Texas USA
    Its telling you to move to a warmer climate.
  17. richard schumacher
    7,663
    1,040
    United States
    <div class='quotetop'>QUOTE(FarmGeek @ Mar 1 2007, 04:49 PM) [snapback]398683[/snapback]</div>
    A radiator blocker will mess up the thermometer.
    You could maybe get it replaced under warranty. Mine agrees within a degree of independent measurements.
  18. Nda3rdCar
    Nda3rdCar Junior Member
    92
    <div class='quotetop'>QUOTE(TomorrowMatters @ Mar 1 2007, 01:26 PM) [snapback]398704[/snapback]</div>
    Hey! It was a while back that we first saw that warning in our A4 Cab. Southern California, we don't see much cold weather. Now we have a Prius (06 Black,#3) for commuting, usually the Cab is a pleasure car. The snowflake warning is a great idea because it really catches your eye.
    Did you purchase an A4 first or the Prius. Just curious. - Nda3rdCar
  19. AAWADKE
    AAWADKE New Member
    71
    <div class='quotetop'>QUOTE(FarmGeek @ Mar 1 2007, 02:49 PM) [snapback]398683[/snapback]</div>
    I dont think so the temperature readings are very close to +/- 1 as far as my experiences are ......and reagarding the mileage ...i have come to conclusion ......it has consistently shown 2MPG higher than i actually get for last 17000 miles i drove
  20. jgills240
    jgills240 Member
    190
    Palmdale, CA
    my goal is to never witness this 'popup'....
