Why does Prime switching modes when cold?
Discussion in 'Prime Main Forum (2017-2022)' started by IABoy987, Jan 19, 2022.
  1. IABoy987
    IABoy987 Member
    199
    79
    Iowa
    2018 Prius Prime
    Have noticed that when outside temperature is much below 32* F, the car switches back and forth from battery to ICE, assuming computer is optimizing the run. When I come to a stop the EV car symbol lights then winks out after a tenth of a mile and ICE re-starts.
    I have read the manual but don't find anything that talks about this low temperature switching (I'm sure its there somewhere). Is this normal to prevent big battery problems or do I have something set to wrong mode, so Prime will run in EV until exhausted?
  2. john1701a
    john1701a Prius Guru
    12,797
    5,280
    57
    That's quite normal. The gas-engine supplements heat when it's really cold, allowing EV by using warmed coolant for heating the cabin. When depleted, the engine runs for a bit then shuts off again.
    Here is an example from mine doing exactly that last winter.
    IABoy987 likes this.
  3. MalachyNG
    MalachyNG Active Member
    304
    225
    Northern NY
    2022 Prius Prime
    I don't know the rhyme or reason but yes it will do that in colder weather. I can go 18 miles+ on EV only when it's over 20°f but my wife will have the ICE kicking in after 5-10 miles on the same route with the same temperature. I'm thinking it's got something to do with driving style and cabin heat settings.
  4. eow
    eow Member
    157
    97
    Winnipeg, Canada
    2022 Prius Prime
    I have not confirmed it yet but speculate that the ICE will come on to achieve the climate control temp setting you have selected when the heat pump is unable to on its own.
    iPhone ?
  5. bisco
    51,155
    try turning the heat all the way down to low, and turn the fan off
  6. Salamander_King
    Salamander_King Senior Member
    11,009
    8,935
    New England
    I've posted this in many threads. But PP has a mind of its own when to turn on ICE and off. In general, the colder the temp the more prone for the ICE to fire. And, once ICE fires and completes the warm-up cycle, it is more prone to re-fire for the subsequent drive
    #6 Salamander_King, Jan 19, 2022
    IABoy987 and dig4dirt like this.
  7. EdPalmer42
    EdPalmer42 Member
    131
    73
    2020 Prius Prime
    When the battery is cold - whatever the car decides is 'cold' - the ICE will start if you call for lots of power from the battery. So with low speed or a light touch on the accelerator, you might be able to run on the battery. But with higher speed or a heavy foot, the ICE will start.
    vvillovv, IABoy987 and dig4dirt like this.
  8. Ovation
    Ovation Active Member
    156
    130
    Quebec
    At -20C, it needs a VERY light touch indeed (haven’t quite been able to do it yet, not for lack of trying).
  9. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    The heat pump will not provide sufficient heat, or any heat at all, below certain temperatures. It won't heat the cabin nor defrost the windshield. Only the engine will get that done when below these temperatures. My older home heat pump below about 34 to 35F spends more time in defrost than in heat. That's when the electric resistance heat elements switch on. In the Prime the gasoline engine starts when the heat pump is inadequate.
  10. vvillovv
    vvillovv Senior Member
    4,318
    1,499
    NY
    This idea is not going to ring well for many, but if you really want to drive EV in "extreme" cold this formula worked for me. And it needs to be done with the heater OFF, windows open if necessary because they're getting foggy
    The simple part is, If the ICE fires. you/re going to fast ! ie: if in extreme cold the ICE fires at the same spot in a routine trip, it's (the car) has pasted a point of it's programming tipping point for EV only propulsion, and going slower up and until that point will sometimes let the driver stay in EV mode. If you still get the ICE firing at the same point, you have to go even slower, up and until that point. The EV System(s), need to warm up too, and there's a lot of COLD in the system. that needs to warmup from use in Extreme Cold before that EV system will allow the electric systems to work solo, without the ICE adding waste heat for (it, the EV system(s)) to use.
    It gets more complex when figuring in the full daily or typical drive. There are a ton of variables that change how the Prius operated due to typical drive that it does it's best to be most efficient with.
    So what works for one Prius driver, doesn't always work for others, with a unique daily drive scenario. And that's the biggest part most drivers don't get for a long time.
    LIke I mentioned above, this is not going to appeal to the common driver who just wants to drive the car and have car do as its commanded.
    see @EdPalmer42 post #7 above.
    Please Don't Forget, that running in EV mode in extreme cold by bypassing the Prius efficiency programming can and will reduce the cars Electrical Systems life cycle, much in the same way that running the Prius too HOT will.
    #10 vvillovv, Feb 23, 2022
  11. IABoy987
    IABoy987 Member
    199
    79
    Iowa
    2018 Prius Prime
    Thanks to everyone's input. I was just concerned that I had missed something and the Prius was having a problem(s) with cold that perhaps needed a trip to Toyota dealer to resolve.
  12. The Big Sleaze
    289
    63
    'frisco
    2020 Prius
    Two Eco
    My Prime's ICE kicks on in "EV" mode if I use the rear window defroster heated wire gizmo, but not if I use lots of cabin heater.
