Why does ScanGauge II show less than max MPG in EV?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by CaliforniaBear, Aug 3, 2013.
  1. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,179
    289
    Northern California
    ScanGauge II shows various MPG values in EV (the ICE isn't running). It shows higher values at higher speeds. Does it assume some small amount of gas is always used? Or is the car providing this information with the same kind of assumption? Or... what?
  2. Drdiesel
    Drdiesel Active Member
    585
    152
    Monterey CA
    I have a new Scan Gauge II, too. I also noticed this data result. I would guess it's basing it off the vehicle speed.
    Did you set it up for Hybrid ?
    48,944
    maybe it's confused because there is no such thing as miles per gallon of electricity.:p
  4. Drdiesel
    585
    152
    Monterey CA
    They call it MPGe :eek:
  5. bisco
    48,944
    whoever they are.:cool:
  6. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    The Mpg-eeeeee's:whistle:
  7. Drdiesel
    585
    152
    Monterey CA
    The Greenies :ROFLMAO:
  8. CaliforniaBear
    1,179
    289
    Northern California
    Yes, hybrid. It certainly has something to do with speed but it doesn't make any sense. :(
  9. retired4999
    2,652
    625
    Eau Claire, Wi.
    (y)
  10. john1701a
    john1701a Prius Guru
    12,747
    5,243
    57
    It's just a "double-value" gauge. Rather than becoming useless when the engine is off, you get a mock power-meter in place of the 9999.
    Having upgraded from an old ScanGauge to a new one, I liked seeing that change. That direct correlation to speed is informative, even if it doesn't actually represent the MPG itself.
  11. Adam Leibovitch
    498
    102
    From Walter Lee in a previous thread:
    Because the faster the Prius is traveling without sipping gas the higher the Prius' iMPG will be.
    Mathematically speaking it looks like this...
    MPG = (miles/gallon)
    MPH = (miles/hour)
    GPH = (gallons/hour), 0.00 to 0.02 GPH means the ICE is turned off
    MPG = MPH/GPH
    1707 mpg = 35 mph/ .0205 GPH
    745 mpg = 15 mph/ .0201 GPH
    Read more: http://priuschat.com/threads/yet-another-scanguageii-question-on-ev-mpg.115599/#ixzz2bm9LbMfh
    Follow us: @PriusChat on Twitter | PriusChat on Facebook
    CaliforniaBear likes this.
  12. CaliforniaBear
    1,179
    289
    Northern California
    Oh, like the friction brake says -.02 when it is off. Thanks for the info!!
  13. Adam Leibovitch
    498
    102
    Someone can correct me if I am wrong, but I think the scanguage only records RPM's, MPH, and time. Then uses a matrix of formulas to arrive at the other values. So fuel remaining for example, is just the SG2's best guess based on the inputed values for rpm's and time in operation, etc.
  14. pwp1943
    pwp1943 PHEV Afficionado
    51
    Boston
    2013 Prius Plug-in
    I have a 6 month old PIP and have tried to plug in my 3.5 year old Scangauge II. The things I liked to observe most on my old Gen 2 Prius aren’t available for display. I sent an e-mail to the Scangauge help desk about this and the said they couldn’t help. They pointed me to Prius Chat. I found the Excel SS showing codes discovered by PC members but there is nothing there for the PIP. Has anyone found the codes for State of Charge, Battery Voltage and Battery Amps for Plug In Prius?
  15. CaliforniaBear
    1,179
    289
    Northern California
    Inspire3 likes this.
  16. john1701a
    12,747
    5,243
    57
    That's because there isn't any difference. Those codes should work fine... assuming your ScanGauge is running a new enough firmware version to support them.
  17. pwp1943
    51
    Boston
    2013 Prius Plug-in
    Are you talking about the excel spreadsheet? I've seen that and there is nothing there for PIP. There are settings for prior generations of Prius. Is there another source of data that I have not yet seen?
  18. pwp1943
    51
    Boston
    2013 Prius Plug-in
    Since mine is 3.5 years old, it might need an upgrade to understand the new codes and digital traffic from the CAN bus in the PIP. I will contact the help desk at Scangauge and see if that is possible. They may even have field upgrade software that can be downloaded and installed from a PC. Can you see SOC, BTA and BTV on your gauge?
  19. CaliforniaBear
    1,179
    289
    Northern California
    From that spreadsheet these all work for me.
    Gauge TXD RXF RXD MTH NAM Note
    Seat Belt Beep Query 07C021A7 046115A70000 2808 000100010000 SBQ C0 for stock, 00 for disable
    Seat Belt Beep Disable 07C03BA700 047B15A70000 2008 000100010000 SBS Should return A7. Replace '00' with 'C0' to go back to stock.
    Reverse Beep Query 07C021AC 046115AC0000 2808 000100010000 RBQ 40 for disabled, 00 for enable beeping
    Reverse Beep Disable 07C03BAC40 047B15AC0000 2008 000100010000 RBS Should return AC. Replace '40' with '00' to go back to stock.
    State of Charge 07E2015B 0441855B0000 2808 03E800FF0000 SoC xx %
    Friction Brake Sensor 07B02107 046145070000 2808 00020001FFCE FRI 0.00-4.50 (Shows actual friction braking amount)
    A/C Power Usage 07E2217D 0461057D0000 3808 003200010000 ACw xxx watts
    Fuel Level (US Gallons) 07C02129 046185290000 2808 13880EC90000 Flv x.x US Gallons, updates quickly
  20. iluvmacs
    iluvmacs Member
    280
    104
    Madison, WI, USA
    I find that Torque on my Android phone is doing something similar. Sometimes in EV mode, it shows 255; sometimes it shows some other random value o_O
