Why does the car come with a jack and other tire changing tools
Discussion in 'Prime Main Forum (2017-2022)' started by EyePrime, Feb 4, 2019.
  1. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    In the owners manual, they show how the scissor jack is under the rear seat and there is a breaker bar/socket wrench that fits on the lug nuts.
    But why? The car doesn't have a spare tire to repair on the side of the road so technically its just dead weight.
    How would this jack and breaker bar help me in any way if I already have a hydraulic jack and decent tools for switching the tires (Winter/Summer), Im considering taking them out of my car.
    road2cycle likes this.
  2. schja01
    schja01 Senior Member
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    Good question.
    I purchased a spare so I'm glad to have them.
    They add weight to the car so it's a bit surprising Toyota would
    include something that wouldn't normally be of use.
    Just a WAG:
    If you get a flat and you can't follow the procedure to drive the car to distribute the goop in the tire you could jack up the car and spin the tire by hand. At least a rear tire. So the sealant coats the inside of the tire uniformly to keep the tire balanced?
    Seems a bit of a stretch if I do say so myself.
    EyePrime likes this.
  3. EyePrime
    268
    115
    2018 Prius Prime
    Im thinking its maybe a law to include the breaker bar and scissor jack
  4. schja01
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    Need to see of those cars that come with run flats as standard equipment come with jack and wrench.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I'm just going to think, that the weight of those tools have to be non-impactful as far as MPG and efficiency.
    So?
    I think it's better to have than not have, even if the most important part of changing a flat tire is missing, with the absence of a spare.
    You can write some semi-complicated scenarios where having a scissor jack and breaker bar would still be of value.
    For me however, they turn out being more like "Scooby Doo" cartoon scenarios, where you use the tools to capture "Old Man Jenkins" who's been posing as the ghost of a Pirate.
  6. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    FYI, our 2005 AWD Sienna that came with run-flat OEM, did NOT come with a jack and wrench. Optional spare tire kit did include that. So, that means, there is no law requiring a jack and wrench in every car, at least not back then in 2005.
    BTW, I do too carry a full-size spare in the back of PRIME now, so having a jack and wrench are good thing. At least they are hidden in the compartment that does not take any more space in the cargo.
  7. bisco
    52,391
    I think you have to jack it up to use the compressor and goop
    pghyndman and Trollbait like this.
  8. Salamander_King
    11,024
    8,970
    New England
    Not according to Toyota.
  9. bisco
    52,391
    only on the mirai, the hydrogen does the heavy lifting:p
  10. eroeder
    eroeder Junior Member
    72
    22
    Dallas
    2018 Prius Prime
    Wow,
    Some folks carry a full spare? Cargo area is not that big, I guess they don’t need space for daily needs.
  11. Salamander_King
    11,024
    8,970
    New England
    OK, just for you! ;)
  12. Mendel Leisk
    41,904
    ^ Hmm, no mention of jacking it up.
    Nice rims.
    (There's no way I would do this btw. In that scenario, a plug-repair kit would be much less "invasive". I would dub it permanently repair, but it's debatable.)
    Trollbait likes this.
  13. Salamander_King
    11,024
    8,970
    New England
    On the contrary, I usually need full cargo space in my PRIME for cargo, but not for people. I can live with a two-seater. My PRIME's rear seats are almost never used, so I have them folded down all the time. I place a full-size spare behind the front passenger seat. The headrest of the rear seat has to be removed, but with this set-up, the full-size spare is very tightly wedged in. Unless you have a roll-over, the tire is not going to fly out.
    IMG_20180920_175807.jpg seats
    #13 Salamander_King, Feb 4, 2019
    SeattleBebop1, KrPtNk and walterm like this.
  14. bisco
    52,391
    i want to see someone do it in real life. in the dark. in the rain. in the mud. in the middle of nowhere.
    don't forget to apply those stickers!:p
    WilDavis likes this.
  15. Salamander_King
    11,024
    8,970
    New England
    In those situations, I would have a hard time changing a tire. Period. I will call AAA.;)
  16. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
  17. Lee Jay
    5,850
    4,036
    I just changed a tire for someone, in the dark, on the ice, using tools that came with the car with which I was unfamiliar.
    Took about 10 minutes.
  18. Washingtonian
    Washingtonian Senior Member
    726
    621
    I wonder if that sealant goop will destroy the TPMS in the rim. I believe that it also destroys the tire by making it non repairable. Obviously a plug-in repair kit is a better solution.
  19. JGC61
    JGC61 Active Member
    216
    104
    Long Island
    Where did you purchase the tire cover?
    Thanks
  20. Trollbait
    12,686
    Manufacturers are moving to electric parking brakes because it save 13 or fewer pounds.
    Considering past experience with cheap compressors, I'd jack up the car just to reduce the work on the factory supplied one.
