Why does the Prius seem to blow tail light bulbs so often
Discussion in 'Gen 2 Prius Main Forum' started by Ichiro, May 3, 2010.
  1. Ichiro
    Ichiro Member
    335
    SF
    I just had to replace one of the tail light bulbs on my '08 Prius.
    In all my 20 years of owning cars, I've never had to replace one before on any of them.
    Also, I've noticed that a lot of other Prius cars with a blown tail light.
    Is it just me or does the Prius wear out taillights faster than other cars?
  2. dejongj
    dejongj Member
    171
    Whipsnade, UK
    Most i see of that age have LED taillights...But besides that there are no reasons for them to blow sooner, besides perhaps a robot forgot to put on their gloves when swapping a tail light bulb...
  3. GeekEV
    GeekEV Member
    417
    NorCal, USA
    Strange. I've got an '06 with 46k on it, no problems. I don't think I've ever seen a prius with a tail light out either... I think your statement may be just a tad overly broad, without enough data points to back it up.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Same here: '06 with 50k and the original bulbs. I've never seen a Prius with a burned out taillight. I have, however, replaced bulbs on pretty much every car that I have owned.
    Tom
  5. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    It's only the brake lamps that are LED on the Prius.
    If you are blowing tail lamps it could be a bad batch was used in production or there may be a poor connection (lamp flickering while driving due to the poor connection which will age it faster).
    I haven't had one blow yet on Pearl (but I just jinxed that!).
  6. hill
    8,187
    Knock on wood ~ all of our lamps are all between 6 & 7yrs old and haven't lost one yet. Now watch ... I'll go out to the parking lot and POOF ... 3 or 4 will let the smoke out!
  7. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    I was pulled over about a year ago with a tail light out, at that time the car was 3.5 years old. Since then I notice it more and I'm with you, there seems to be a disproportionate amount of tail lights out on Prii.
    Edit: One nice thing is that they are cheap and extremely easy to replace.
  8. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i've had one blow. i've had many occasions when the there was a poor connection so it looks blown (most prii you see on the road with tail lights out have this problem)
    i've even received ticket for having a light out, when it was simply a poor connection. i check all my lights before i drive at night... just to be safe.
  9. halpos4
    halpos4 "Taxi"!
    377
    24
    Ireland
    +1 on how cheap they are and easy to replace,
    I've had a few blow over the 4 years i've had mine but that's working nights,lights on for 10-12 hour shift but only costing €1 for a box of 10 capless bulbs,one can't complain.
  10. bisco
    49,498
    how do you check you brake lites? back up against a wall?
    i've never replaced a bulb on my 04 or 08. or noticed one out on another prius. i guess you'll get a lot on both sides of this. a poll maybe?
  11. mdt1963
    mdt1963 New Member
    pa
    the bulbs are fragile #192 bulbs usually used in small marker lamps in other applications
  12. tmorrowus
    tmorrowus Member
    514
    I was surprised when my 04 Prius had a rear brake light go out after just a few years, since they lasted 7-8 years in my previous car, so I do think there's an issue, but it's so easy to replace that who cares.
  13. halpos4
    halpos4 "Taxi"!
    377
    24
    Ireland
    I check my brake lights using an expensive piece of equipment,high maintainence and quite fragile....her indoors!!
  14. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    Mine just blew last weekend... :)
  15. a_gray_prius
    2,927
    782
    IL
    I keep a few replacements in the under-trunk compartment just for the hell of it.
  16. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    I suppose if swomeone is really burning out a lot of bulbs they should check their '12v' level. If it's high, like 14v, I would think your bulbs might not last as long. Getting the dc-dc converter fixed will probably cost more than the bulbs, though... although if it's that high your 12v battery is getting cooked, too.
  17. dejongj
    dejongj Member
    171
    Whipsnade, UK
    :eek: That's how you break them :D:p
    kenoarto likes this.
  18. desertrider2215
    156
    usa
    I have replaced the front lights by the headlight on the top corners, both back ones (NOT the LED) at least twice. Also the license plate lights sometimes tweak out. Seems weird..
  19. Patrick Wong
    18,200
    6,474
    1. Odometer reading?
    2. Are you an owner who leaves exterior lights on at all times when driving during daylight hours?
    3. Have you measured voltage across the 12V battery when READY? It should be ~13.8V. If much higher, that is the reason why your bulb life is short.
  20. desertrider2215
    156
    usa
    2. Yes
    3. I haven't, i'll check it out.
    thanks!
