Why Gen 3 catalytic converters are harder to steal...
Discussion in 'Gen 3 Prius Main Forum' started by Georgina Rudkus, Jun 28, 2020.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,153
    2,204
    Taylors, SC
    It has to do with the heat exchanger and engine pre-heater behind the catalytic converters.
    Removing a Gen 3 cat requires four cuts in the correct places, and the thief will be sprayed with coolant from the heat exchanger, which can be boiling hot.
    https://www.youtube.com/watch?v=06HvMEVKdwg
    #1 Georgina Rudkus, Jun 28, 2020
    Willy Toast, Mendel Leisk and Merkey like this.
  2. Mendel Leisk
    38,652
    Also not as much precious metal?
  3. Georgina Rudkus
    3,153
    2,204
    Taylors, SC
    The reduction in precious metals started with the Gen 4. The converter with the greatest amount of precious metals is the one closest to the flange connected to the exhaust manifold before the second oxygen sensor. Since it converts the majority of the NO, the second one does less.
    Without a larger amount of precious metals, the Gen 4 converter needs to be larger, as shown in the attached photo. Prius Gen 4 exhaust.jpg
    Joonnoon19 and Mendel Leisk like this.
  4. Georgina Rudkus
    3,153
    2,204
    Taylors, SC
  5. Georgina Rudkus
    3,153
    2,204
    Taylors, SC
    I have to admit that I was wrong about the Gen 3 cats being harder to steal than those of the Gen 2 Prius.
    The same technique of cutting the oxygen sensor wires, removing the two spring loaded bolts to the engine's exhaust manifold and one strategic cut with a Sawzall is all that is needed, just like the taking of a Gen 2 cat.
    The only caution for thieves is knowing where the pre-heater coolant lines are and not cutting into them.
    Neverbox and Mendel Leisk like this.
  6. Neverbox
    Neverbox New Member
    San Jose
    >Removing the two spring loaded bolts to the engine's exhaust manifold
    Spot weld them in place? Round the corners? LocTite?
    Seems like a small amount of high quality rebar welded to the pipe would stop a sawzall.
    And, if you obscure their view with a shield then the thieves might not know what tools they need for the job.
