Why is one of my 08' Prius noticeably louder than the other
Discussion in 'Gen 2 Prius Main Forum' started by sas0611, Sep 30, 2008.
  1. sas0611
    sas0611 Member
    230
    I have 2 '08 prii. One of them seems to now be somewhat noisier on the road than the other. The predominant noise I am hearing is one that modulates with speed of vehicle. There is a concentric component to the sound which makes me think its related to tires or worse case bearings. My guess is that the noise is due to something related to the tires. They both have OEM goodyear integrity tires. Quick inspection finds no large stones in the tire treads but will check more closely if you think this is possible cause. Here are the variables:
    Vehicle A (increased road/tire noise) / Vehicle B (less noisy)
    Mileage-------> 13,000-------------------- 3,200
    Tire Rotations --> 2 ------------------------ 0
    Alignments ------>0 ---------------------- -- 0
    Equipment ------>#5 ------------------------#6
    Special Notes: Vehicle A which is more noisy has had 2 tires rotations - performed at 2 different Toyota dealerships. On the latest rotation at 11K miles I observed that the work was not carefully performed as witnessed by lack of attention to tire pressures. The pressures were wrong after rotation - apparently who ever rotated the tires left the original pressures in the tires. I'm not even sure if they rotated them front to back or crossed them (should have paid closer attention to where I found the pressures but just was so pissed that I quickly adjusted them myself).
    Questions:
    1. could improper rotation (diagonal instead of front to back pattern) cause the integrity tires to 'sing' more than they do when new ?
    2. could the 13000 miles on vehicle A versuses 3000 Miles on vehicle B's tires account for the additional noise ? Have you noticed the original tires becoming noisier with more miles on them ? Is this expected with 13000 miles or is it more likely after more mileage than 13K.
    3. I don't think this is the case but is the #6 package better noise insulated inside than the package 5 ?
    4. Could the hack that rotated my tires left a lug or two loose on my wheel ?
    5. Could this be something worse like bearing ?
    As usual - thanks in advance for your comments folks..
  2. Patrick Wong
    18,210
    6,510
    1. Diagonal rotation should be OK for tires that are not unidirectional.
    2. If this bugs you and you have access to jackstands and a hydraulic floor jack, why not swap the tires from one car to the other and see if the noise travels.
    3. No
    4. Certainly possible, suggest you check the lug nut torque which should be 76 ft.-lb
    5. Possible although unlikely at the low mileage that you have logged.
  3. dogfriend
    7,512
    1,190
    Carmichael, CA
    I agree with Patrick's answers above. One additional thing to contemplate: if you have an alignment issue that is causing uneven tire wear, it may cause the tires to get more noisy as they wear unevenly. Hobbit has reported this with his car, and I have experienced this with the Ford Explorer that I own.
