Why no Trac Off button
Discussion in 'Gen 3 Prius Technical Discussion' started by Hugh, Jun 10, 2010.
  1. Hugh
    Hugh New Member
    23
    Minneapolis
    My only complaint about my Prius and Camry Hybrid is that I can't turn off traction control. I live in Minnesota and there are times when I need full throttle in slippery conditions. I notice the Lexus HS250h which has the same drivetrain as my Camry Hybrid has a Trac Off button.
  2. Eoin
    Eoin Active Member
    593
    116
    Long Island
    I think it is to prevent damage to the hybrid drive train.
  3. Hugh
    Hugh New Member
    23
    Minneapolis
    That is what I was told. But then it should be the same for the Lexus HS250h
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    As pointed out above, it is to prevent damage to the HSD. However, that begs another question: How can the Lexus HS250h do it without the same risk of damage?
    Tom
  5. silentak1
    silentak1 Since 2005
    893
    28
    LA
    Because the Lexus is perfect. The Toyota is not. At least according to their ads... "in pursuit of perfection".
    All bad jokes aside, very interesting question... time to start coming up with crazy theories until someone intelligent comes up with the real answer. I'll start...
    The Lexus might have better tires and with trac control OFF, the tires will still grip...
    The Lexus might have extra bolts and parts holding the HSD so it will withstand the abuse...
    The Lexus trac-off may not a true 100% trac-off...
  6. cthindi
    cthindi Member
    177
    85
    Connecticut
    I don't really understand how Traction control protects HSD. Differential may be. Is it because differential pumpkin is also present in same housing?
    Traction control as I understand will help in wheel digging itself in mud or snow pile. It will also help when one side hydroplanes and losses contact with ground.
    But as far as transmission is concerned output speed of transmission is average of two wheel speeds. Why not an override as it exists in most cars and in Lexus HS250h ?
    Does the unofficial override of inspection mode work in gen 3 the same way as in gen 2?
  7. Hugh
    Hugh New Member
    23
    Minneapolis
    The Lexus tires are the same crappy 20,000 miles tires as on my Camry Hybrid. The Trac Off function is a full off function as is on all other Lexus vehicles
  8. silentak1
    893
    28
    LA
    ok sir you debunked 2/3 of my points... :)
  9. qbee42
    18,058
    3,076
    Northern Michigan
    With the Gen II Prius such as yours, traction control only controls the power output. When either drive wheel spins significantly the traction control system cuts the power to both wheels. It will not help with a wheel digging in, or with hydroplaning, other than cutting power.
    The electric motor on the Prius gives it a lot of low end torque. Without some sort of traction control system it would be easy for inexperienced drivers to spin the drive wheels. Spinning drive wheels present two possible problems: 1) Overspeed of critical parts, and 2) Shock loading if and when the drive wheels grab. Either of these can destroy your HSD.
    The Gen III Prius employs selective braking in addition to power modulation. In this respect the Gen III system is true traction control which will help you when only a single tire slips.
    Tom
  10. cossie1600
    cossie1600 Active Member
    903
    94
    CT
    the lack of a tcs off button is a safety hazard in my mind, one of the worst decision on the car
  11. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    Sometimes if it just wouldn't have stopped both wheels quite so soon you could make it, but once your stopped there is no hope except calling for help. Unfortunately I was 600 miles from home 30 miles from the nearest town and totally without cell phone coverage. I was on my way to Reno last month and decided to stop have lunch and go for a hike down by the lake.
    Fortunately an angle of mercy came by in the guise of a Washoe County Deputy and called a tow truck on his radio. Tow truck showed up in about 45 minutes pulled me out using the rear tow hook, no damage except to my ego. Tow truck came from Fernley NV, real nice guy, only charged me $180 which State Farm paid no questions ask.
    Sorry about the quality of the photos, used cell phone camera.
  12. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I recently took a 2010 Toyota Venza AWD V6 for a spin. It has a Trac Off button
  13. Tideland Prius
    16,445
    Yes Jayman.. but it's a regular car. My friend's 1999 Camry XLE V6 has a TRAC OFF button too so it's not like Toyota doesn't include them. It's only on hybrids. I find it odd that the HS' TRAC OFF is full off.
  14. cossie1600
    903
    94
    CT
    Traction off isn't going to help you in that instance
  15. tumbleweed
    4,067
    690
    Eastern Oregon
    Correct, it would only help if you knew ahead of time you were entering an area where you might have trouble. If I had known that I wouldn't have gone there to start with. It might have helped if the traction control had allowed some wheel spin instead of stopping both wheels completely. What did help was having to get towed out because I'll be more careful next time, I hope. :)
    My BMW had a very useful traction control system. Full on it limited the engine to about 1500 RPM, you could turn it 1/2 way off so it still used the brakes to stop one wheel from spinning more than the other but allowed the engine to rev to about 3500, the next push of the button turned both stability control and traction control off. But I think that car has a very strong (and heavy) drive train, you have to give some things up for efficiency.
    I need to watch for low traction areas in the desert, Prius doesn't make a good dune buggy. Maybe it's time to look at a RAV4 or an FJ Cruiser, or the equivalent from Honda, to go with the Prius?
  16. Hugh
    Hugh New Member
    23
    Minneapolis
    But my Camry Hybrid operates exactly the same as the Lexus HS250h with the same drivetrain. I unerstand the Lexus CT 200h which will have the Prius Gen III drivetrain will also have a shutoff button. So I still do not understand why the Toyota Hybrids do not have the same option. We really need it.
  17. qbee42
    18,058
    3,076
    Northern Michigan
    Which is why I said:
    Tom
  18. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    If it's such a "safety hazard", why are people driving these vehicles? Why not get something you feel "safer" in? It's not a car for everyone and every situation. Maybe a bit of discretion when driving in limited traction areas. it certainly does the job for 95% of the driving out there.
  19. Hugh
    Hugh New Member
    23
    Minneapolis
    I checked with the head mechanic at Lexus of Maplewood. He said the Trac Off button does shut off the traction control, but traction control will automatically come back on when the vehicle reaches a certain speed which he believed was around 30MPH
  20. john1701a
    john1701a Prius Guru
    12,797
    5,279
    57
    Use better tires. The factory ones leave much to be desired. I noticed a big improvement with my 2004 in Minnesota.
    With my 2010, you'll notice a big improvement... even with the factory tires. The newest generation eliminated the need.
