why should i
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Emtedee, Dec 12, 2016.
  1. Emtedee
    Emtedee New Member
    Australia
    As the original post said "I don't understand why rolling the windows down apparently doesn't wipe it off, every car I've ever had before this did that." That again must be a design fault. Why oh why stop the side windows getting cleared when you roll them down and back up again. Why should I have to walk round the car in the pouring rain to clear the rain from the side windows, another bloody good reason why I loathe this car and wish I had never heard of it
  2. eliteconcept
    eliteconcept 700 mile club, top tank mpg 69.5
    449
    186
    Indiana
    2022 Prius Prime
    you signed up for this forum specifically to complain about the windows? Come on...
    What are your other complaints
  3. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    Put some RainX on them and the problems solved.
    49,500
    i make my wife do it.
    DonDNH likes this.
  5. drysider
    drysider Active Member
    823
    332
    Liberty Lake WA
    You have to clear the rain off of the windows? Snow maybe, but rain? Really? Does it stick more down in Oz?
  6. slewinson
    slewinson Junior Member
    36
    30
    Australia
    Two words - hydrophobic coating. Easy fix - sell it and leave this forum.
    Simon
  7. eliteconcept
    449
    186
    Indiana
    2022 Prius Prime
    whats with the posts recently from these new "owners" with silly complaints and claims.
    bisco and slewinson like this.
  8. slewinson
    36
    30
    Australia
    Yep, seems like they want a new and economical car that uses innovative concepts to behave exactly like their old crapbox.
    Simon
  9. bisco
    49,500
    actually, the question should be, 'why shouldn't i'?
  10. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    The 3 latest new vehicles I have purchased....2 honda Fits...1 Prius..all shared this characteristic.
    While it can seem inconvenient that you can't simply roll your window down to remove water like a automatic squeegee, I actually think it's "intelligent design".
    Because the rest of the year or when it is dry, having a tight fitting window gasket only serves to rub dust against the window, which I think can end up scratching it.
    I think I can either wait for the wind from driving to blow the rain away from my side windows....or I can take a second or two to wipe my windows and side mirror before I take off.
    I'm not convinced having the "squeegee" level window gasket IS actually the best.
    Plus...I live in the Pacific Northwest...rain..rain and water falling from rain....
    And at about 20 mph...any raindrops on my side window...are not an issue.
    Gravity and the wind...takes care of that....
  11. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    Have you considered selling it?
  12. drysider
    823
    332
    Liberty Lake WA
    My experience with rain is that, without Rain-X or equivalent, it would immediately recoat the window.
  13. slewinson
    36
    30
    Australia
    I suggest selling the Prius and buying a life!
    Simon
    DonDNH likes this.
  14. Robert Holt
    Robert Holt Senior Member
    1,313
    888
    Had cars where I had to replace the side window rubber squeegee things after they had crumbled due to aging. I noted increased water and "junk" infiltration (seeds,leaves, dirt) when those squeegees were absent, which resulted in clogged drain holes in the bottom of the door and then increased rusting due to water accumulation in the lower door. It was a mess to clean up, so I would favor the tight-fitting squeegees if given that option. Has anyone tried to retrofit better squeegee things in a Gen 3?
  15. slewinson
    36
    30
    Australia
    Why? when the windows are closed there is no gap for crud to get into the door cavity. Also, on my Prius the drain holes are huge - just crack the window and gently hose out all of the accumulated crap with a slow stream of water.
    Also, isn't cleaning out the drain holes once per decade or so something that should be done? I look at them when I open the door - they are so obvious.
    The car's design is correct, just not what you are used to from the dark ages.
    Simon
  16. Montgomery
    Montgomery Senior Member
    2,254
    2,238
    Orange County, CA
    All the replies are killing me. (I have a sense of humor) I hope the original poster sees the humor and is surviving this!
