Featured Why two-motor hybrid systems are better than those with just one
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Jun 30, 2017.
  1. bwilson4web
    15,513
    Source: Why two-motor hybrid systems are better than those with just one
    Six years ago, we wrote that a number of single-motor hybrid systems were about to enter the market.
    They represented a new approach to a technology pioneered in 1997, when the first-generation Toyota Prius was launched in Japan.
    Through 2010, all the full-hybrid vehicles introduced by Ford and General Motors used systems designed around a pair of motor-generators
    So this was my comment:
    In 2005, there was a single motor, Honda IMA, and the two motor, Prius. I chose the system with the higher ratio of electric-to-engine power and never looked back. But technology moved on.
    The Prius Prime has two electric motors that with the one-way clutch can work as a single motor. There are no 'shift points' so the transmission remains mechanically simple and the ride smooth and quiet in contrast to the Ioniq Blue that I test drove.
    It is possible to make a single motor, hybrid with similar, no-shift point, performance like our BMW i3-REx. So it is not the motor count but how much they make the ride quiet, smooth, and without the frantic-motion of a shifting transmission.
    Thoughts? Be sure to copy them to the article comment section.
  2. Trollbait
    11,514
    There reason for why the two motor is better is weak, and they even acknowledge that.
    I was actually hoping for a more technical comparison, such as cost differences.
    The reason we are seeing one motor, full strength parallel hybrids now is that the coordination of the system components was simply not possible when the Prius first came to market. The drive experience may not be flawless at this time, but so were blended regen and friction brake systems back in the day. This could improve in time for the hybrid system.
    Then there are people that prefer shifting over CVT like driving. The article even had a negative to say about power-splits on that front.
  3. hill
    8,159
    i never bothered to consider GM's volt (gen 1 or 2) that much, over the years - but Bob's putting forth the 2 motor / 1 motor debate caused me to go looking - & this was what i found . . . . from the Volt's engineer - explaining the how & why's of 1 versus 2 motors.
    i thought he made a good case - & stated it in a way that my simple mind could easily grasp.
  4. Tideland Prius
    16,128
    I edited the title @bwilson4web to match the title of the article you linked. It made a touch more sense as I found "motor count article" to be a bit ambiguous. :)
    bwilson4web likes this.
  5. bwilson4web
    15,513
    Nice video that also points out there are no stepped gears involved. The last GM transmission schematic I'd seen was the 'two-mode' and it was ... sad.
    hill likes this.
  6. El Dobro
    El Dobro A Member
    6,978
    3,213
    The Gen 1 Volt also worked in single and twin motor configurations, depending on the speed.
  7. kevinwhite
    kevinwhite Active Member
    331
    199
    Los Gatos Ca
    There are two motor-generators in the BMW i3-Rex. It just happens that one of them is always a generator (the one in the range extender).
    kevin
  8. bwilson4web
    15,513
    By that logic, every EV has two motor-generators with one somewhere in the grid and the other in the car.
    You do realize that the generator does not have to operate at the same time as the motor, right? It a subtle distinction.
    #8 bwilson4web, Jul 1, 2017
  9. kevinwhite
    331
    199
    Los Gatos Ca
    From that aspect Mg1 doesn't always have to have any power going to it in the Prius.
    I think the main distinction between the Toyota/Ford approach and the others is using a secondary motor instead of a changeable gear set - a series hybrid such as the i3 is closer to the series/parallel method than the single motor used in IMA or others.
    kevin
  10. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    To be fair, there's several levels of 2-mode system - the simplest form (as used in the Allison H40EP/EP40/H50EP/EP50, the Gen 2 Volt, and the current Malibu hybrid) isn't much more complex than a Prius transmission. The one used in the pickups, OTOH, had a lot going on.
    In any case, really, the biggest problem with 1-motor systems boils down to the fact that it's hard for them to switch between engine off and engine on operation. The Honda IMA vehicles got around this by not even trying to propel the vehicle with the engine off - the engine has to be running to get propulsive force. And, the Ioniq actually is technically a 2-motor system, because it has a small motor/generator on the engine's accessory drive belt, primarily for starting the engine so it can rev match smoothly with the rest of the system.
    Trollbait likes this.
  11. bwilson4web
    15,513
    Depending on speed, MG1 can be a generator or a motor to move the car. Often called heretical mode, it increases the counter torque so the engine turns slower. In contrast, the generator of the BMW i3-REx plays no mechanical part in driving the wheels.
    Some form of power-split device might have been a better question than one or two motors.
  12. Trollbait
    11,514
    The article's entire argument for a power-split being better than a parallel system is this, "We've concluded that single-motor systems simply get caught out more by sudden on-off acceleration: we haven't driven one that wasn't at least slightly lumpy or jerky at some point."
    By that argument, friction only brakes on the brake pedal is better than having regen also controlled by it. This is a very subjective criteria in which to declare one better than the other. As I said, I was really hoping for something more substansive.
