Wierd Lemon-Lime color on battery bar
Discussion in 'Gen 2 Prius Technical Discussion' started by valleyvillage, Sep 20, 2007.
  1. valleyvillage
    valleyvillage New Member
    Sometimes my battery bar light goes from blue (normal) to this weird lemon-lime color. Is that normal?
  2. mgipe
    mgipe New Member
    50
  3. Ari
    Ari New Member
    165
    <div class='quotetop'>QUOTE(valleyvillage @ Sep 20 2007, 12:30 PM) [snapback]515329[/snapback]</div>
    Do you also notice more bars than when it's blue?
  4. Winston
    Winston Member
    614
    SF Bay Area, California
    When one or two bars - Color is purple
    When 3-5 bars - color is blue
    When 6-7 bars - color is lime green
  5. Spoid
    Spoid New Member
    286
    My kids cheer when it turns that color.
  6. justifyd
    justifyd New Member
    60
    <div class='quotetop'>QUOTE(Winston @ Sep 20 2007, 02:57 PM) [snapback]515378[/snapback]</div>
    On mine, it's purple for 1-2 bars, blue for 3-6 bars, and green for 7-8 bars (well, I've never been up to eight bars, but I do get to seven on a regular basis).
    - Justifyd
  7. blamy
    blamy Member
    380
    Central Florida
    What do you have to do to get the bars all the way to the top! I can get it up to "1 to go" but have never got to the top. Drove from florida to New York once a two day trip with about 10 hours on the road the first day and still couldn't get that final bar to show!
  8. john1701a
    john1701a Prius Guru
    12,749
    5,243
    57
  9. Frank Hudon
    Frank Hudon Senior Member
    4,147
    <div class='quotetop'>QUOTE(BuddyL @ Sep 23 2007, 01:52 PM) [snapback]516611[/snapback]</div>
    9 miles of 6% grade will do it every time.
  10. stumpy_c
    stumpy_c New Member
    50
    <div class='quotetop'>QUOTE(Frank Hudon @ Sep 23 2007, 07:06 PM) [snapback]516662[/snapback]</div>
    I've gotten it twice, only when going downhill (a lot), but I live in the mountains.
  11. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    <div class='quotetop'>QUOTE(BuddyL @ Sep 23 2007, 04:52 PM) [snapback]516611[/snapback]</div>
    I was going to suggest driving in very cold weather, but I see that for you cold is 50F :D
    I get green a lot more in the winter simply because the ICE is running to keep itself at temp. Its really painful to be at a stop light with 5 blue bars and the engine running, charging the battery. Add some hill and that 8th bar will show up. The REALLY funky thing is if you get it too well charged, the car will run the ICE to pull power out of the battery. I had that happen once coming down a really long hill. Got to the signal at the bottom, 8 green bars and the engine started and ran a bit, stopped, then did it twice more. Too bad it didn't know I was getting on the interstate in .25 miles :( Fortunately I had read about that scenario here because until I remembered reading it, I thought my car had a serious problem!
  12. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    <div class='quotetop'>QUOTE(valleyvillage @ Sep 20 2007, 11:30 AM) [snapback]515329[/snapback]</div>
    Also remember when it's full it isn't full. The computer only lets it range from 40% up to 80% state of charge in normal operation (If memory serves, which sometimes it doesn't) ;)
