wierdness with brake system pressure buzz
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Diotima, Mar 9, 2013.
  1. Diotima
    Diotima Junior Member
    47
    SoCal
    folks,
    My 2005 Gen II just did something odd. I drove it about 8 miles to the zoo and parked it for 4 hours.
    When I got in, that brake pressurizing buzz sounded. Startled the bejeebers out of me as I don't ever remember hearing it when I get IN the car. No warning lights, but when I turned the car on, the battery was on two red bars.
    The car drove fine on the way home.
    When I parked it at home, the pressurizing buzz came on as I was getting out. Normal, right? But then it cycled on and off about 7 times. Never heard that before. I had to go inside before I could see if it stopped on its own but I went back about 15 mins later and stood there listening. Nothing. So I got in and pressed on the brake pedal w/o turning the car on, and yep - same noise.
    Still no warning lights.
    Is this normal and I've just never noticed it before, or is something going wonky?
    Thanks in advance!
    Kary
  2. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    The "cycling on and off about 7 times" part is wonky. Otherwise, yes, the brake pressure pump can turn on when the driver's door is opened, but not always.
    Diotima likes this.
  3. Diotima
    47
    SoCal
    Ok, I'll have to keep an eye on it, then.
    Thanks. :)
  4. nh7o
    1,686
    340
    Hawaii
  5. Diotima
    47
    SoCal
    FYI, it hasn't done it again. This happened immediately after a 5-day sojourn above 6,000 feet (I live at sea level) with 20F temps at night. No clue if that might have affected anything.
