Will 17” 2013 Prius wheels fit a 2007 Prius?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Jonathan Clarke, May 12, 2021.
  1. Jonathan Clarke
    Jonathan Clarke Junior Member
    Providence, RI
    Four Touring
    Does anyone know if I’d be able to put the 2013 Prius wheels on my 2007 Prius? I know the bolt pattern on both is 5X100 but the offset is 50 on the 2013’s and 45 on my 2007.
  2. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    should fit.
  3. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    According to this website, they are the same...
    Here is a more detailed calculator...
      File size:
      82.3 KB
  4. ttou68
    ttou68 Active Member
    348
    205
    They should be the same.. 5 X 100 and 54.1mm center bore..
