Will 195 60 15 size tires affect GPS positioning ?
Discussion in 'Gen 2 Prius Main Forum' started by sas0611, Aug 18, 2010.
  1. sas0611
    sas0611 Member
    230
    I know the effect of mounting 195 60 15 will play into speedo and mpg readout but I'm thinking there should be no effect on NAV guidance system ? Am I wrong about that ? I don't want GPS guidance telling me to make a right turn too late or early. Thanks in advance.
  2. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    Nope! GPS works off a signal from a satellite. It may, however, affect your speedometer depending on the difference in circumference from the OEM tire.
  3. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    58
    Fullerton CA
    There is a menu somewhere in the NAV system (look for it - I don't know off hand where it is) that lets you put it into calibrate mode when you get new tires.
  4. Paul58
    1,126
    125
    Atlanta
    Man, Toyota engineers think of everything! Does this calibration make adjustments to the speedometer as well, or is it just to make the GPS arrival time calculations a bit more accurate?
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The OEM Nav system includes a dead reckoning system, which helps the Nav system keep track of your location during loss of GPS signals. Setting the calibration on the Nav system improves the calculations, but does not affect the speedometer.
    Tom
  6. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Factory GPS systems often use the odometer and a compass or accelerometers to update location when you don't have an adequate GPS signal.
    The one in my Chevy does a reasonable job of keeping track of position and direction in large parking garages and long tunnels without GPS signal. It's made by the same company as the Toyota system.
