Will 2012 Prius spare work on 2023 Prius XLE AWD?
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Lou Echeandia, Sep 7, 2023.
  1. Lou Echeandia
    Lou Echeandia New Member
    Shelby Twp, MI
    2023 Prius
    XLE AWD-e
    I am purchasing a 2023 Prius XLE AWD which has no spare tire, however I have a 2012 Prius D16 spare. The 2023 has a 19" diameter. Will it fit and be safe to use on the short distance I would take on the unlikely chance it would be necessary?
  2. Mendel Leisk
    38,874
    Not a chance. If I’m not mistaken even the bolt pattern is different.
    what does D16 mean btw?
  3. Lou Echeandia
    Shelby Twp, MI
    2023 Prius
    XLE AWD-e
    The full tire identification is "T135/80 D16 101M Tubeless"
  4. Hammersmith
    Hammersmith Senior Member
    1,403
    1,442
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    It means it's a bias-ply tire and not a radial. Radial would be R16. Radials are better in general, but a bias-ply is fine for a temporary-use tire like a spare.
  5. Hammersmith
    1,403
    1,442
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    And correct that the bolt pattern is different. The 2012 spare won't even fit on the 2023 wheel hub, much less dealing with the 8.2%(2.2") height difference.
    Oops. Meant to edit my earlier post, not quote it.
  6. Leadfoot J. McCoalroller
    7,236
    6,783
    Pennsylvania
    2018 Prius c
    Even if it did fit, I wouldn't feel very safe with an 11+ year old tire.
    They really do have a shelf life, even though it is commonly ignored.
    If you're going to go through the trouble of carrying a spare and tools, do it right and start with a new tire. Then replace it every 7-10 years depending on climate and the results of an annual visual inspection.
