Will 2016+ EGR cooler fit in a 2012?
Discussion in 'Gen 3 Prius Technical Discussion' started by ZPV12, May 12, 2019.
  1. ZPV12
    ZPV12 Junior Member
    30
    2012 Prius v owner, but I thought to post here about my question as the ECR cooler is a common part, and thought there may be more traffic to the Prius liftback tech section.
    I am trying to understand the differences between the EGR cooler for the gen 3 (part number 25601-37010) and 2015+ which have a part number of 25601-37020. Anyone know if there are any physical differences between the two, that would result in the newer part not fitting into a 2012? There seem more used parts for less money, for the newer units which also have much less miles.
    Anyone have any experience with this?
  2. CR94
    CR94 Senior Member
    2,783
    1,222
    Northwestern S.C.
    No experience, but I have heard the newer ones source exhaust differently (from after the converter), so likely are not interchangable.
  3. ChapmanF
    18,782
    Maybe somebody will try blocking off the bung on the exhaust manifold, and adding one to the pipe downstream of the converter, and shoehorning a Gen 4 cooler in somehow.
  4. ZPV12
    ZPV12 Junior Member
    30
    Spoke to my mechanic yesterday and he said to not mess with trying to use different part numbers, regardless of how similar they look.
  5. ThatDudeOrion
    ThatDudeOrion Member
    95
    87
    Central, NJ
    This thought has crossed my mind as well, but I'm also wondering if the Gen 4 cooler itself is a better design, or if we wouldn't be equally well served to just move the location the exhaust gas is drawn from to post-cat and extend the EGR pipe from that point to the gen 3 cooler
    mjoo likes this.
  6. Mendel Leisk
    42,090
    @Ragingfit elects to retain his 3rd gen intake/exahust manifolds, and EGR system, when swapping a 4th gen engine into a Prius v (essentially the same process as swapping into a 3rd gen Prius) here:
    Swapping in a Gen 4 Prius' 2ZR Engine into the Prius v | PriusChat
    Exhaust manifold differences discussed here:
    I think with enough mods it could be done. But maybe not worth it.
    FWIW, about 18 months and roughly 10K kms after doing the EGR and intake manifold clean, and Oil Catch Can install, when I checked the EGR pipe recently, it was spotless.
  7. Mendel Leisk
    42,090
    I was wondering if I'd understood, but yeah, that last part number is 4th gen Prius EGR cooler.
    Part #11:
    EGR System for 2016 Toyota Prius | Toyota Parts
    #7 Mendel Leisk, May 16, 2019
  8. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    From Toyota's part diagrams, the gen 4 EGR cooler looks wider/shorter. Maybe less prone to blockage? It makes sense to make it wider since the EGR flow increased in the Gen 4 from 21% to 28%.
    It would be nice to see a side-by-side photo of Gen 3 EGR cooler vs. Gen 4.
    ThatDudeOrion likes this.
  9. ThatDudeOrion
    95
    87
    Central, NJ
    i've got a spare gen 3 on the shelf if someone wants to send me a gen 4 i can do it :)
  10. Mendel Leisk
    42,090
    Meh, just clean everything, and install an OCC.
  11. Coots
    Coots Member
    62
    25
    Hailing from parts unknown, Iowa
    You can see the difference in the exhaust manifolds: For 2016+ Toyota has moved the catalytic converter further upstream, just behind the header collector. This allows them to "roughly" keep the EGR cooler and exhaust to EGR pipe in the same place and downstream of the catalytic converter, drawing "cleaner" exhaust gases back into the engine. It also allows for faster converter heat up, reducing emission quicker after start up.
    I am sure it's possible to use the 2016+ EGR setup on a 2010-2015 model, but not without some moderate exhaust work.
    It may be possible to swap over the entire exhaust system.... making this easier.
    Or it maybe swap over partial exhaust system, welding them together further downstream.
    -A
  12. ChapmanF
    18,782
    Got a bunch of discussion over in this thread here. Turns out the difference between tapping the EGR from upstream or downstream of the cat is a big deal. Downstream is an entirely different, newer technique with its own name ("catalyzed EGR" or "clean EGR") in the engineering literature, and so while, yeah, you might guess there's less gunk in it, it is also a different chemical composition because of the cat's action, and lower pressure because of the cat's pressure drop, so it needs upsized cooler and valve even just to get the same flow, and it has different effects on combustion because of the chemistry, and engines using the two techniques are designed and calibrated for them specifically.
    Needless to say, that makes it something more than a trivial swap.
    mjoo likes this.
