will 2017 Prius rims work on 2008 Prius
Discussion in 'Gen 2 Prius Main Forum' started by christy401, Dec 4, 2022.
  1. christy401
    christy401 New Member
    RI
    I am looking for a used winter setup for 2008 prius. I found a couple of options one is 15" winter set up from 2017 prius . it has 195/65/15 tires on it. My current tires are 185/65/15. other set up is from a 2008 Corolla with 195/65/15 tires.
    Thanks
  2. Tombukt2
    Tombukt2 Senior Member
    9,235
    1,618
    Durham NC
    Either will work fine whichever you can put your hands on for the least money..
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,195
    2,216
    Taylors, SC
    No, starting with Gen 3 in 2010, Toyota switched to a different lug pattern.
  4. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Your "v" wagon is different, but the rest of the family is the same, though please correct me.
    Tombukt2 likes this.
  5. Tombukt2
    9,235
    1,618
    Durham NC
    The 5 lug 15 are same me thinks still ..even in steel .
  6. Mendel Leisk
    38,757
    I'm pretty sure gen 2, 3 and 4 rims are all compatible. On our 2010 (3rd gen) I'm using this rim with snow tires:
    Corolla steel rim, part no: 42611-02471, which were used roughly in the years 2003-2008, maybe for Matrix as well.
    4th gen rims are more-or-lesss the same as 3rd, except for a 1/2" width difference (forget which way), even though the tires for both 3rd and 4th gen are the same: 195/65R15.
  7. xliderider
    xliderider Senior Member
    7,875
    3,117
    Honolulu, HI
    This is not accurate, only the Prius v wagon has a 5 x 114.3 bolt pattern. The Gen 2 through Gen 4 Prius models (not the v wagon) are all 5 x 100.
    The Corolla wheels the OP cited are also 5 x 100.
    ColoradoCrow likes this.
  8. christy401
    RI
    Thanks all!
