Will 5 month annual storage degrade Hybrid battery despite trickle charger on 12 v battery?
Discussion in 'Gen 3 Prius Main Forum' started by Nankoweep, Jun 25, 2019.
  1. Nankoweep
    Nankoweep New Member
    Portland, Or
    Will 5 month annual storage degrade Hybrid battery even though I have a trickle charger on my 12v battery?
  2. David E. Edwards
    David E. Edwards Junior Member
    25
    Sugar Land, TX
    Your trickle charger recharges only the 12v battery which is only used to power-up the
    computers in your Prius. So the Hybrid Battery is separate and being a battery is will discharge
    over time.
    If possible I would have some drive my Prius every month for about 30 minutes so all fluids get
    warmed-up also.
  3. Mendel Leisk
    38,705
    From page 30 of the Owner's Manual:
    That said, our 2010 had build date August 2009, and when we purchased in November 2010 it had 15 kms on the odometer (yes: 15 kms, not 15,000 kms). It's been fine, no issues. Maybe a brand-new battery takes protracted downtime better, not sure.
    Can you get someone to "take it under their wing", drive it periodically? If push comes to shove, hire someone vetted, say a dealership person, mechanic or whatever..
    49,433
    i'm just not comfortable leaving a hybrid for 5 months every year. i always advised my father against it as he went snow birding each season
  5. Nankoweep
    Portland, Or
    Thanks for the response. You might have just saved me a hybrid battery!
  6. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,220
    Madison, Wisconsin
    It would be very hard on an see hybrid battery to sit unused that long.
    You could buy a high voltage trickle charger for your HV pack. It would cost $600-$1000 depending on which one you chose. That could maintain the pack while you were gone.
