Will a failing 12Volt Auxillary Battery adversely affect the hybrid EV battery?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by JImmyPriNew, Aug 25, 2020.
  1. JImmyPriNew
    JImmyPriNew Member
    34
    63
    Hilo, Hawaii
    A few months ago during a scheduled maintenance at Toyota they said my 12volt auxiliary battery failed the CCA Test. They said if I didn't replace it I could get stranded somewhere because it stopped working. I said I would wait. That was 3 months ago. Nothing out of the ordinary has happened. I am getting ready to do a 4 year update youTube video on my 2016 Prius. I want to make sure I get the facts straight. So 1. If it really is failing does that adversely affect the EV hybrid battery? 2. Since I drive downhill directly to Toyota the car computer says the run was on EV battery for over 70% of the time and probably??? not recharging the 12 volt battery. Then the mechanics keep the air conditioner on full blast at its lowest setting and then probably did the test. Could that have caused a temporary failed reading? Or faulty test equipment or whatever? Battery Test.jpg Battery Test.jpg
    alanclarkeau likes this.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    Driving downhill - I can't see that it should affect the 12volt battery. And - as far as I know, it should have no effect on the Hybrid Battery.
    @Elektroingenieur might be able to throw some better light.
    #2 alanclarkeau, Aug 25, 2020
  3. JImmyPriNew
    JImmyPriNew Member
    34
    63
    Hilo, Hawaii
    Thanks alanclarkeau. I'll wait until tomorrow to see what answers I get.
  4. Elektroingenieur
    2,515
    3,284
    Three Touring
    Given the conflict of interest—one presumes the dealer would like to sell a replacement auxiliary (12-volt) battery and labor to install it—I’m not sure I’d accept their conclusion that the battery has failed, without knowing more about their test procedure and pass/fail criteria.
    If they used a Midtronics battery diagnostic system, as Toyota requires mainland U.S. dealers to do when making warranty claims, and the battery’s rating was correctly entered into that system, then I’d be inclined to accept the conclusion. Instruments such as these can distinguish a battery that simply needs recharging from one that has failed, and in any case, using the air conditioner (with the car in READY) or driving downhill is unlikely to have had much effect on the auxiliary battery’s state of charge.
    The printout, however, just says “Fail” and “240.0 CCA.” There are different definitions and test procedures for cold cranking amperes (CCA) in SAE, EN, DIN, and JIS standards, and without knowing which definition applies, or how the measurement was made—or if this was, in fact, a measurement and not a reference value—I wouldn’t rely on it. Consider that if the battery is the original one, it’s marked with a CCA (EN) rating of 295 A, and 240.0—if on the same scale—is more than 80% of that.
    As for effects on the hybrid vehicle (HV) battery, I wouldn’t worry too much. The car has a sophisticated auxiliary battery management system, including protection for the DC-DC converter and HV battery. The real dangers are that the auxiliary battery fails without much warning, leaving you stranded, or leading to an expensive mistake while trying to jump-start the car. You wouldn’t believe how many reports we get on PriusChat that people have confused the + and – terminals, which can ruin your whole day.
    jerrymildred and alanclarkeau like this.
  5. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    Humm, the battery that came in my 2016 toyota prius was rated at 190 CCA. Just saying this out loud
    kenoarto likes this.
  6. alanclarkeau
    7,045
    7,592
    This is a photo I took of mine back - it's still the original, 4¼ yrs old, which in Dog Years is ...:
    Harters likes this.
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    Good to "see" you again, Jimmy. I'm looking forward to your 4-year review.
    As always, @Elektroingenieur gave a great answer. When the dealer said the 12V could strand you, that's the important part. But just seeing 240CCA doesn't prove by itself that the aux battery is about to fail. A simple test you can do at home, if you have a multimeter, is to take it for a 30-minute drive or thereabouts and then check the battery voltage the next morning to see if it held its charge.
    Your climate is similar to mine but without the chilly "winters" and I keep hearing that four years is about average in FL for a 12V battery. However, mine always seem to last longer.
  8. JImmyPriNew
    JImmyPriNew Member
    34
    63
    Hilo, Hawaii
    Thank you for the detailed answer.
  9. JImmyPriNew
    JImmyPriNew Member
    34
    63
    Hilo, Hawaii
    Thank you for your suggestions. 4 year review coming in a few weeks. I have a container garden renovation coming out first.
    alanclarkeau and jerrymildred like this.
  10. JImmyPriNew
    JImmyPriNew Member
    34
    63
    Hilo, Hawaii
    Thanks.
  11. JImmyPriNew
    JImmyPriNew Member
    34
    63
    Hilo, Hawaii
    Thanks.
  12. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    The 12V battery is recharged from the Traction Battery when you are in READY mode, regardless of whether uphill, downhill, ICE or EV. A simple voltmeter plugged in the 12V outlet in the center console will let you monitor the charging operation. When you first enter READY mode, you'll see 14+ volts, meaning the 12V battery is charging. Then, after several minutes, the voltage will drop to 12-13 volts, meaning the battery is recharged. This is a smart DC charging system that is only energized when in READY mode and the 12V battery needs a top-off. By the way, if you press the Power button without pushing the brake pedal, you enter Accessory mode, and you will see the raw voltage of the 12V battery.
    jerrymildred likes this.
  13. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    Back to the original question:
    NO, a failed 12 V will not "damage" the HV battery.
    It might cause it to not fully charge for a while.
    It might cause some codes to come up that LOOK like the HV battery is failing when it really isn't.
    4 years is on the low end of expected battery life so I suggest getting it tested at some other place.
    Is there an auto parts store nearby ? They will often do it for free.
  14. JImmyPriNew
    JImmyPriNew Member
    34
    63
    Hilo, Hawaii
    Thank you for the information
  15. JImmyPriNew
    JImmyPriNew Member
    34
    63
    Hilo, Hawaii
    Thank you for the information.
  16. CooCooCaChoo
    CooCooCaChoo Senior Member
    957
    535
    Cow-lee-fornia
    2023 Prius
    Yeah, more than likely the dealer is selling you a battery + install that you don't need, just yet. CCA is, technically, only important for straight up ICE only cars because the starter motor has to turn the motor over so it can start.
    Because the starter motor is replaced with the motor-generator in the Prius, the power comes directly from the hybrid battery. So a simple measurement like CCA is not enough to diagnose a failing 12v aux battery. Does the maintenance report from the dealer have SoC numbers or internal resistance numbers on it?
    Those are more indicative of a failing battery.
  17. JImmyPriNew
    JImmyPriNew Member
    34
    63
    Hilo, Hawaii
    Thanks for your reply. The maintenance report doesn't have any additional numbers.
  18. bisco
    51,937
    why are you asking question 1? i don't see where the dealer said it affected the hybrid battery
  19. Greivous166
    Greivous166 New Member
    Missouri
    2015 Prius c
    I drive a 2015 Prius 5, and a couple years ago, when I tried to start me vehicle, I got a dashboard warning saying that my 12 volt battery was low. When I took it to the dealership and had the battery tested, they said that the battery had a couple bad cells. Basically the battery was going bad and wouldn't hold much of a charge anymore. After a few more weeks, it got to the point t where the vehicle couldn't 'start', or rather get itself into ready mode. It would take a few tries of turning it off and turning it back on again. Sometimes I would have to turn it into 'standby' mode, wait a second or two, then on to ready.
    I eventually got the 12 volt replaced and it fixed everything. Though it was a bit pricey at $260, but very easy to replace yourself.l, as I did.
    Somebody can correct me if I have this wrong, which I might, but I believe the 12 volt is your starting and running battery, while the 'hybrid' battery is for driving and charging the 12 volt. I hope this was helpful.
  20. jerrymildred
    11,517
    14,152
    Tampa, FL
    Welcome! Please allow me to clarify a couple things for you.
    There is no "standby" mode.
    1. With the foot off the brake, pressing start once puts it in Accessory mode. Some stuff works and the 12V is the sole power source.
    2. With foot still off the brake, pressing start a second time puts it in on mode. all electrical components can be use. The 12v is still the sole power source.
    3. Pressing start a third time turns the car off.
    Putting a load on the 12v briefly will often cause a temporary bounce in that battery and give you enough power to start the car. It's an old old trick with gassers in cold weather. Best accomplished by running the headlights for a short time, but doesn't do much these days if you have LED headlights. LOL!
    The 12V only turns on the computers, lights, etc. on initial start. Once the computers are ready (takes an almost imperceptible amount of time), the realys in the hybrid battery close and then that battery starts the engine, propels or helps propel the car, and provides all the 12v power except when the MGs are generating. That's pretty oversimplified, but the point is that the 12V does not start the car like it gasser 12V starts the car. The 12V system gets it power from the HV system via the DC/DC converter. For some more information:
