Will a Prius float in water?
Discussion in 'Gen 2 Prius Main Forum' started by SixInchPrius, Dec 11, 2005.
  1. SixInchPrius
    SixInchPrius New Member
    24
  2. Kiloran
    Kiloran New Member
    1,225
    Uh...what are you planning? :p
  3. Vincent
    Vincent Don't Wait Until Tomorrow
    641
    31
    South Florida
    Let Us Know How You Do!
  4. tochatihu
    tochatihu Senior Member
    9,548
    3,683
    Kunming Yunnan China
    2001 Prius
    [attachmentid=1363]
    Attached image from a few years ago.
    Based on where fine dust deposits in the vicinity of the doorseals, I am convinced that it is not watertight. The high voltage wiring passing under the body is enclosed, but also not guaranteed waterproof. Please operate Prius in terrestrial mode only.
  5. littleprius
    littleprius New Member
    53
    If all else fails, maybe try enclosing your Prius in a "protective package" like a Prius condum available at your local Toyota dealer! :lol:
  6. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    Sure no problem. Just head out on the nearest lake and when the ice breaks through you'll stay warm an comfy. :)
  7. MarinJohn
    MarinJohn Senior Member
    3,945
    304
    Can you close the door without opening a window?
  8. SixInchPrius
    24
    Maybe you got a good point. The cold water might slightly shrink my Prius resulting in a tighter sealer against intrusion of water from the outside.
  9. 8AA
    8AA Active Member
    550
    62
    Maryland
    It might, but it’s not advisable. Homer Simpson tried it and ended up electrocuting a pod of dolphins and a harem of mermaids. Of course that was in an Electaurus, not a Prius.
