Will a steam clean mess with the plastic on the dash?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MrChristian, Mar 24, 2010.
  1. MrChristian
    MrChristian New Member
    31
    Washington
    I've got a 90lb dog that managed to come loose out of his harness in the back seat. While he was out of his harness, and we while were away from the car for 10 minutes, he managed to crawl out of the back and onto the front passenger seat where he drooled all over the sloping dash. Flash forward 9 mos and it's still a stain that manages to persist. I was thinking a good steam cleaning would probably get into all the fine nooks that I wouldn't otherwise be able to get (well, without shredding the vinyl wipes).
    Anyway, would the steam clean be safe for the plastic or would I run the risk of warping it? Also would the steam cleaner be ok for the leather seats?
    Many thanks in advance!
  2. Fuel Miser
    Fuel Miser Junior Member
    86
    22
    Ontario, Canada
    Steam and a Prius dash is not likely to work out well.
  3. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Well other than the melting part, steam is at least 212 degrees, and I would think the plastic mght have an objecton!!
  4. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Are you for real?
    The Prius is a computer with a car attached. I don't think it wise to introduce large amounts of steam to it. There are many other ways of cleaning the interior, but steam isn't one of them.
  5. New_Yorker
    New_Yorker New Member
    517
    69
    Since 'Dog Droole' is not toxic, and it requires no solvents to remove, I would suggest mild but effective cleaning solutions. No harsh chemicals that could damage the plastic , and use them with great finesse. Think Q-Tips, Paper towels wrapped around things to insert into cracks and crevices. If laundry detergents can remove the stuff from clothes a mild solution of warm water and Tide will probably clean the dash also. A soft brush for urregular uneven surfaces then a wet towel to rinse, and a dry towel to dry. TIME and EFFORT is what it will take to return the car to pre-Dog condition, not extreme heat or chemicals.
    ask araes not in need of cleaning, and tape up all places that moisture should not enter. Then chaulk the experience up to needed education for Dog Owning Prius Drivers.:)
  6. pjksr02
    pjksr02 Active Member
    532
    225
    Connecticut
    I'd agree with New Yorker: use elbow grease as much as you can. Toothbrushes are also a great tool for crevice cleaning. But, be sure to use microfiber on your display screens...
  7. MrChristian
    31
    Washington
    I spent about 20 minutes yesterday using water and a microfiber cloth to no avail.
    The "plastic" seems more like a dense foam than plastic. And it's in the really fine nooks that the drool seems to be residing. I've got a fear of introducing other "ingredients" into these nooks. When the cabin's humidity rises the blotches of drool really appear and it's really unsightly.
    The "steam cleaner" that I have is more or less used for straightening delicate fabrics and isn't a steam pressure cleaner. I'm glad I asked, because I really don't have a lot of experience with steam and this particular material. My fear of using a detergent (or other chemicals) would be adding more to the "splotchiness" factor. Also, I'm under the impression that no amount of training/dog education would stop a dog from drooling. We fixed the harness situation, however, believe you me. Thanks for the posts and thanks in advance for any subsequent posts/suggestions.
  8. Carnutt
    Carnutt Member
    232
    23
    SW USA
    2018 Prius
  9. pjksr02
    532
    225
    Connecticut
    I'm not sure it would work on hard plastic, but I've used Woolite's "pet stain remover with oxygen" on carpets and upholstery, and it works very well. You can find it anywhere. It's a spray, so maybe try spraying it on a cloth, then applying to the affected area.
    Also, I once saw a segment on "Dirty Jobs" about a company that cleans up vehicles after serious accidents. If worse comes to worse, consult the pros!
    Good luck!
  10. MomPortlandOR
    MomPortlandOR New Member
    Portland, OR
    Hey there - since it's under warranty each dealership has a partner detailing shop - so i suggest you call them to help with the cleaning of the dash. When I went to pick up my new Prius - it looked like there was a water stain on the dash so they drove it over to the detailing shop and they used a vinyl cleaner i believe. that way they help fix it. Also re: the dog - I too have a large dog 80 lbs and that was my first concern when looking at the prius. the salesperson told me that a client of hers pulls out the trunk top and then you have that deeper space which gives the dog about another 6" or so of head room. you could put a blanket down in the back and covering the tops of the backseat in case he/she drools over them.
    goodluck! liz
  11. Patrick Wong
    18,200
    6,472
    I agree that you could ask your dealer to help you clean the dash.
    Or if you still want to DIY, you could remove the dashboard plastic so that you can clean it more thoroughly outside the car. However this will not be easy to do. You'll need to disconnect the 12V battery first, and may have to deal with the passenger-side airbag in the dash.
    Consult techinfo.toyota.com for repair manual info.
  12. Joe166
    Joe166 New Member
    720
    96
    South Florida
    Enjoy your dog. We lost two dogs about two years ago to sudden illnesses and I promise you that every time we come across a drool stain we almost lose it! We now have a new dog and as much as we love him, you never forget them.
