Will an iPhone work with the 2010 USB interface?
Discussion in 'Gen 3 Prius Audio and Electronics' started by Faraday, Sep 3, 2009.
  1. gnawfish
    gnawfish New Member
    NC
    I have this same exact problem IrishGuyJay. Any luck with finding an answer?
  2. Carnutt
    Carnutt Member
    232
    23
    SW USA
    2018 Prius
    This is what I found: the 3G iPhone will work with your car's Bluetooth and download your phone book and utilize the hands-free car controls. If you plug the phone into the usb port with the adapter, it becomes just an iPod mp3 player and apparently disables the phone and will not charge it while connected.
  3. xanmato
    xanmato Junior Member
    31
    Seattle
    Phone: Iphone 3G
    Bluetooth: working
    USB charging: working
    USB integration: working
    Everything still works when plugged into USB
    Device not compatible fix:
    1. Remove bluetooth connection profile from prius (phone section AND audio section)
    2. Remove bluetooth connection profile from iphone
    3. Restart iphone
    4. Plug iphone into USB and integration should work (you still have normal yes/no popup)
    5. Re-add iphone to prius (do not re-add bluetooth in audio section, just phone bluetooth)
  4. R2Pre2
    R2Pre2 Feel the Force!
    111
    24
    SF Bay Area
    2018 Prius Prime
    thanks for this summary. i'll try it and hopefully it will work. now...if we can just get the airplane mode pop-up fixed...
  5. xanmato
    31
    Seattle
    Sadly, the airplane mode popup is here to stay, unless toyota makes a 'works with iphone' certified version. Hardware manufacturers must certify their devices and pay Apple a fee to put a Hardware authentication chip inside the device, otherwise you get the pop up.
  6. johntylko
    johntylko Junior Member
    Santa Clara, CA
    my family just got a 2010 prius IV with navigation, and our usb port now recognizes the iphone 3GS as an iPod, after it is also paired as a phone..it will accept a charge and show playlists on the screen, although i did notice the buggy interface here (scrolling through songs selects changes whats playing)
    oddly enough, we threw an 5th gen ipod classic in there and it isn't accepting a charge anymore. the prius is only a few days old, is it possible its defective? the iPod will accept a charge from other chargers (a griffin autopilot)
  7. willrob
    willrob Junior Member
    33
    Madison, Wisconsin
    Just to update this thread. I have an iPhone 6 and an iPod Nano (current version). Both use lightning connectors. Both work with my Prius 2012 via BT. Neither work via USB. The USB system works with an older 30-pin iPod touch and with a thumb drive, but the newest tech from Apple's mobile devices cannot access the audio system via USB.
Loading...
