Will dirty cabin filter trigger the check engine light?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Moegs, Feb 5, 2014.
  1. Moegs
    Moegs Junior Member
    Western Wisconsin
    My check engine light came on. Did not read it for codes. Day later I replaced the cabin air filter (not in response to the check engine light, just routine maintenance). Check engine light went off after driving about 8 miles. Are they be related?
  2. JC91006
    16,674
    8,519
    Cabin Filter usually doesn't trigger the check engine light. Maybe a loose gas cap would. The DTC is logged so whenever you get a chance, you can retrieve the code.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Motor oil dangerously low.
  4. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Change of emphasis.
  5. JC91006
    16,674
    8,519
    Well that's what I meant :)
  6. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
    It's not uncommon for a CEL to go away after a while if the error condition that triggered it has stopped, or doesn't exist anymore.
    Could be an intermittent cylinder misfire, etc.
    SCH-I535
  7. Moegs
    Moegs Junior Member
    Western Wisconsin
    ok..thanks will check the OBC tomorrow. no further replies please.
