will heated side view mirror work ?
Discussion in 'Gen 2 Prius Main Forum' started by withoutapaddle, May 23, 2018.
  1. withoutapaddle
    withoutapaddle Junior Member
    17
    sacramento
    The wife used a concrete column at a parking garage to erase the passenger side view mirror from our 2006 Prius...need to replace it. I've found a used mirror, from the same year & same color as the car, but it is a heated mirror. Our Prius does not have that feature. I've also found a black mirror which, does not have the heating feature so it is an option. The cost isn't an issue for either, each are less than $75 which is fine with me. So the issue is.... if I purchase the red mirror...with the heating feature....is that a safety issue? Will the plug at the end of the mirror be compatible with what is in the car right now? Bottom line---will the red/heated mirror work or will it not (or will it be a safety issue?) or do I need to simply buy the black one?
    Thank you!
  2. JC91006
    16,482
    8,400
    All the mirrors from gen2 are heated
    SFO likes this.
  3. withoutapaddle
    17
    sacramento
    What?..... I had no idea..... no need for it...but.... thanks.
  4. withoutapaddle
    17
    sacramento
    So how does one operate a heated mirror? I don't drive the car much but I've never seen a switch to turn it on.
    SFO likes this.
  5. JC91006
    16,482
    8,400
    It's turned on by using the rear defroster
    SFO and valde3 like this.
  6. JC91006
    16,482
    8,400
    The mirror colors are just a cover, if you can safely pry your black cover off, you can put it on the replacement mirror
    SFO and withoutapaddle like this.
  7. ChapmanF
    15,622
    The claws that hold the color cover in place poke through into the inside of the mirror. After popping the glass/carrier out (this post describes how, with a picture of the two clip locations to release), it is very easy to reach inside and release/push out the color cover claws, no prying or forcing needed.
    -Chap
