Will it cost me all the money i saved in gas to get a new battery?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Eneder772, Nov 19, 2014.
  1. Eneder772
    Eneder772 Junior Member
    Atlanta, Georgia
    So exactly how much does it cost to replace the battery on a 2011 prius? I heard it will be about $2500. I figure thats about all the money i saved in gas for the past 3 years, maybe more. Kinda feeling lousy.
  2. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    Well we have had very few if any cases of Gen3 batteries going bad at all in the US.
    You are warranty covered in GA for 8-yr 100k miles.
    Realistically, assume the gas savings you have now, triple that because you need to go say 9-10 years to see a problem ...now subtarct Prius maintenance costs...usually works out pretty good.
  3. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    If I called Toyota for an estimate, parts and labor, it would be nearly $3k. Apparently there are cheaper ways to get battery replaced / fixed. Consumer Reports did a survey this year finding only like 5% battery failures in 2002 Prius. More like 2 and 1% after that and down to .1% recently. **
    Civic Hybrid had 8 to 32% failure rates in CR survey for 2002 to 2010 models, yikes!
    Saved in gas over what? Let's say a Corolla or Civic. They're likely 32 MPG combined.
    You're probably in an 8 year / 100k mile battery warranty state. Keep in mind these batteries are very reliable.
    Average cost of gas is a guess, let's $3.75 / gallon avg. over 8 years. So, Prius is 375 / 50 = 7.5 cents per mile, Corolla is 11.7 cents / mile. You save 4.2 cents per mile.
    So, in 100k miles, you run out of battery warranty. (.042 $ / mile) x 100k miles = $4,200 saved in gas over the Corolla (or Civic, etc...) More than enough to get the battery and some left over to help in cost diff between the two cars.
    For someone who doesn't drive much, say 6k mile / year, after 10 years, they've only saved $2,520 , not as good.
    There's a lot more to look at with maintenance costs too, but decent rough estimate.
    #3 cycledrum, Nov 19, 2014
  4. JC91006
    16,482
    8,397
    If you sell the car now, you'll be ahead
  5. Chuck.
    2,766
    1,510
    Lewisville, TX (Dallas area)
    Check out third party places that might service packs...Dallas has one, so I bet Atlanta has one way cheaper than a dealership
  6. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    you can get it rebuilt for around $900, my 04 is still on the original battery, check the 12 volt in the trunk
  7. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Let's pretend you have a Prius with 100,000 miles, (or 10 gears) how likely are you to use new parts? A remanufactured battery with a 3 year warranty is available for about $1700 installed, if you are adventuresome, you can eBay a used battery for $900 and install it your self.
  8. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I smell BS or a troll or someone up to mischief.
    The OP has a 2011 car and is complaining the cost of replacing a battery negates the savings in fuel. If they're within the 100k mile warranty then there is no worry on replacement costs and if they're already over 100k mile then they will have saved a lot more than $2,500 in those 100,000 miles.
    Nothing to complain about there.
    ewxlt66, usnavystgc and SageBrush like this.
  9. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Perhaps they are just really bad at math. Honestly, if you are having issues, give details. Toyota (not the dealer) often goes the extra mile.
  10. GregP507
    GregP507 Senior Member
    3,002
    480
    A better question might be, "how do I calculate whether my Prius saved or cost me money?"
  11. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    The warranty on the HV battery in the US is 8 years/100k miles OR 10 years/150k miles depending where you live. That sounds a pretty damn good warranty to me.
    The warranty on the HV battery in the UK is 5 years/100k miles BUT can be extended for free upto 11 years UNLIMITED mileage whilst using a Toyota dealer for servicing. Our warranty laws are different and include commercial use.
    I'd love to know why the OP has a concern. I'd also be curious which manufacturer he is comparing his car against which offers similar warranty?
  12. bisco
    49,455
    did you buy a prius to save money? hahahahaha, you should have bought a bicycle.;)
    Mr. Bubbles, vskid3 and usnavystgc like this.
  13. GregP507
    3,002
    480
    Can't argue with that.
    I haven't saved money by buying a Prius, but I still get the satisfaction of getting 50 USMPG.
    Mr. Bubbles likes this.
  14. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    It takes the better part of six years until fuel/maintenance/repair savings exceed upfront costs.
  15. bisco
    49,455
    six years?!? by then you'll need a new battery.
    and don't forget gasoline deflation.
    #15 bisco, Nov 19, 2014
  16. GregP507
    3,002
    480
    If payback were the only factor, a bicycle beats them all.
  17. bisco
    49,455
    a used bicycle. too much initial depreciation on a new one.
  18. SageBrush
    11,627
    2,530
    Southwest Colorado
    That's nothing. I read on the internet that the inverter craps out after two years, and you do not even want to know how much the El_cheapo_made_in_China Flux capacitor costs.
    Debatable.
    As a poor college student I made it through 6 years on one pair of sandals. No punctures, either.
    #18 SageBrush, Nov 19, 2014
  19. GregP507
    3,002
    480
    You got me there. No debate necessary.
    GrumpyCabbie likes this.
  20. SageBrush
    11,627
    2,530
    Southwest Colorado
    Too bad. I thought you were going to play the 'time is money' card. I was ready, though: a race on ice!
