Will my 2009 Prius run on gasoline once the electric battery is dead?
Discussion in 'Gen 2 Prius Technical Discussion' started by glrooney, Dec 1, 2021.
  1. glrooney
    glrooney New Member
    Waynesville, NC, United States
    I have a 2009 Prius. The electric battery is still okay. But, once the electric battery is dead, will the car run on gasoline only?
  2. Tim Jones
    Tim Jones Senior Member
    1,742
    562
    SE Texas
    2011 Nissan LEAF
    NO..................................................................................
  3. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    If the car senses a problem with the hybrid battery system it will shut down that system and then car will run on gas engine only until you turn the car off and then it won't run at all until the error codes are cleared or the hybrid battery is repaired. To prevent warning lights/hybrid system shut down getting you stranded use one of these Hybrid battery diagnostic and repair tool for Toyota and Lexus and Dr. Prius app on your phone to clear error codes to hopefully make it home without the battery pack overheating. It's wise to have one of these in your glove box!
  4. Tim Jones
    1,742
    562
    SE Texas
    2011 Nissan LEAF
    I guess it depends if you were asking if you could use the car without the traction battery....... NO..................
  5. rjparker
    rjparker Tu Humilde Sirviente
    9,597
    5,894
    Texas Hill Country
    Not really. The high voltage has to be available for the inverter and transaxle to work. HV is necessary to start the gas engine. You can have an extremely bad hv battery in terms of capacity but it is necessary to start the gas engine everytime. No hv battery voltage means the car won't run. You can get into a situation where the gas engine is doing all the work and never turns off during normal driving. But getting the car to start after shutdown requires the hv battery.
  6. glrooney
    glrooney New Member
    Since my hybrid battery in Prius 2009 is only going to last 100,000 miles, and that is where we are now, Can replacing cells be a cure? I am not technical at all, but I have read posts discussing this. If it is true, where do I go to get this done? We are in our 80s, and cannot buy a new hybrid battery when ours fails. Please be specific in your reply, remember, I am OLD.
  7. Tim Jones
    1,742
    562
    SE Texas
    2011 Nissan LEAF
    You might want to sell it and get a non hybrid.
    New Batteries are $1600 not installed.
    100,0000 is low mileage.
    And the batteries can go way past 100,000 miles but there is a time limit on
    the pack..... best to save for a new battery pack especially if you plan on keeping the car longer.
    Trying to swap out individual batteries is a real pain...... and the the others will fail.
    Total nightmare especially if you don't know what your doing.
    #7 Tim Jones, Dec 9, 2021
  8. fuzzy1
    10,335
    How do you know that?
    In certain states it came with a 150,000 mile warranty, though also with a time limit that you are a couple years past. While numerous older Prii have had battery problems, many others are still on the road with original batteries.
    dig4dirt likes this.
  9. rjparker
    9,597
    5,894
    Texas Hill Country
    Don't fix it if it is not broke.
    And your age is not an excuse in 2021. Buying another car these days is way more expensive than a new hybrid battery when the time comes.
    Don't buy used tires and don't buy used hybrid batteries. Ever. Your original battery at 100k is better than a used, reconditioned, repainted or "guaranteed" rebuilt alternative. You are good until at least 150k miles or higher.
    Bottom line: If your dash is not lighting up like a Christmas tree with bulbs you have never seen, you are good. Don't let the do it yourselfers here scare you.
    #9 rjparker, Dec 9, 2021
  10. nancytheprius
    nancytheprius Active Member
    357
    153
    iowa
    Does your battery hold a steady charge? A somewhat easy but not super technical way to know would be to look at the energy monitor screen. Does it stay at the 6 blue bars consistently? Or do you see a lot of fluctuation between the pink or purple (cant remember) for 2 bars and green for 8? what is your mpg and driving conditions?
  11. nancytheprius
    357
    153
    iowa
    This video will give you some understanding as to how the hybrid system works. around 13:50 it talks about how the engine assists MG2 but at no point does the engine and MG1 propel the car by itself
  12. Another
    Another Senior Member
    1,818
    515
    Naples, Florida
    My 2007 has nearly 200k miles on it and the original battery is in great shape.
    Mainly depends on how often the car is driven.
    glrooney and nancytheprius like this.
  13. nancytheprius
    357
    153
    iowa
    has it been in florida its whole life? original battery there this many years later would surprise me!
  14. Another
    1,818
    515
    Naples, Florida
    no, most of it's life in the Chicago area.
    nancytheprius likes this.
  15. bisco
    51,155
    have you considered giving up your licenses?
  16. glrooney
    glrooney New Member
    No and don't plan to until I feel I am a danger to myself or others. I am fine mentally and physically and have no health problems.
  17. rjparker
    9,597
    5,894
    Texas Hill Country
    Totally inappropriate comment.
    Tim Jones likes this.
  18. bisco
    51,155
    thank you forum police
