Will not go over 65 mph
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Steves2005, Mar 15, 2009.
  1. Steves2005
    Steves2005 Junior Member
    Maryland
    a n00b here, I did a search , did not find anything and looking for help.
    My son called me, he is driving home from spring break in his friend's 2008 Prius, the car will not go over 65 mph and when they get up over 60mph the "Skidding Car" light flashes.
    The car has about 5100 miles and is almost new.
    Any clues to what could be wrong?
  2. richard schumacher
    7,664
    1,043
    United States
    Are there crucial facts missing: there's a combo kayak/bike rack on top, it's towing a horse trailer, the hatch is filled with cinderblocks for the friend's dorm bookshelf business, ...?
  3. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Something doesn't add up here. If it's that new, see what the dealership says
  4. Steves2005
    Maryland
    I called him, the car is not fully loaded, just two people and their suitcases. I guess we will bring it to the dealer tomorrow and see what is wrong, they are on their way to my house now.
    When it first started happening this morning, they stopped at a Jiffy Lube, had the oil changed and the tire pressure adjusted and fluids checked.
  5. richard schumacher
    7,664
    1,043
    United States
    The rated load limit is 825 pounds.
    They do know to stop immediately if they get the check engine light or the big "!"?
  6. Steves2005
    Maryland
    Yes, they are watching for other problems, right now the only warning they have is when they get up to about 60mph the "Skidding yellow car" lights up
  7. jayman
    13,439
    641
    Winnipeg Manitoba
    Oh god, you might as well stop typing right there.
    :rolleyes:
    I'd rather push my car 10 miles than take a chance on an Iffy Boob. The horror stories are ... horrible
  8. Steves2005
    Maryland
    The car had the problem before they went there, I imagine the maint light was on soild at 5100 miles and they figured an oil change would help their situation.
  9. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    Just guessing here, but doesn't the flashing VSC light mean the car is getting bad VSC data from a sensor? As a result the car could be backing off on the throttle. Anyone?
  10. maseace
    maseace Prius enthusiast
    191
    Poulsbo, WA
    The skidding yellow car icon is Traction Control or "slip indicator light" (not VSC). The VSC warning light is not an icon, just the letters "VSC." Which one is it? Or both?
  11. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    It is possible that the car is receiving bad data from the sensor. That would make sense.
    My second guess is that the car's owner attached a governor to the Prius. Ask your son how fast they drove down to Spring Break. At least, whether they went above 65 without problem.
  12. Patrick Wong
    18,200
    6,492
    Hi Steve,
    It would be nice to pin down exactly which warning lights are on.
    For fun, when the car gets to your home you might check the engine air filter and the snorkel leading to the engine air filter housing to make sure that:
    1) the bottom of the filter is not particularly dirty (which it should not be after only 5K miles), and
    2) there are no obstructions leading to the snorkel like a rat nest, a plastic bag, etc.
    I'd also suggest that you check the tire air pressure yourself to verify that all four tires are properly inflated, at least 35/33 psi front/rear when cold. Also inspect the tires and wheels to see if any physical damage is evident.
    If you don't find any problems there, and assuming that the VSC and/or skidding car warning lights are still on, then I suggest that a Monday morning visit to your local Toyota dealer would be in order.
    Good luck.
  13. Steves2005
    Maryland
    Thanks for the info, since I do not have VSC in my Prius, I assumed that was the indicator for it. My son told me that the "Skidding yellow car" indicator light is lit, sorry for the confusion.
  14. jayman
    13,439
    641
    Winnipeg Manitoba
    If it's a 2008 Prius, have this guy swing by a dealership and ask them what is wrong. It's all but impossible to properly diagnose second hand/third hand information like this. Too much "he said she said" background noise
  15. Steves2005
    Maryland
    That is the plan, to take it to the dealership tomorrow. I was hoping to find some knowledge here that could have helped them on their way so that they do not miss classes tomorrow.
    What I found out is that this has never happend to anyone here in the past.
    You should not fly off the handle about he said/ she said - background noise, I miss spoke about one fact, I did not know the VSC and "Skidding car" icon were not the same.
    :focus:
  16. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    the only time i've had vsc kick in while trying to gain speed is when my ignition coil was going bad. is the car surging or anything? does he always carry around people? a car full of people with excess driving can flash the oil. i know your car is new.. but i did that with synthetic. (if anyone knows excess weight in their prius.. it's me...)
  17. Steves2005
    Maryland
    What do you mean by "flashing" the oil?
  18. jayman
    13,439
    641
    Winnipeg Manitoba
    I was trying to state the fact that we have nowhere near enough data to work with. It's not your car, your son was in it. Your son relayed data to you, and you relayed data to us
    It has been my experience that such relay of data is fraught with errors and inconsistencies. The HSD is a very complex system, to delve into all the possible fault codes requires the Toyota diagnostic tool.
    A generic diagnostic tool cannot command the HSD system, and cannot retrieve all the codes. A generic OBD tool will retrieve Federally mandated OBD II data, that's it
  19. jayman
    13,439
    641
    Winnipeg Manitoba
    He thinks a combination of a longer oil change interval, and very hard driving, caused the oil to evaporate and his engine ran low on oil
  20. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    they're not running on the spare tire, are they?
    skidding car icon is traction control, so one of the wheel sensors is probably giving a faulty reading. probably related to a wheel impact on a curb somewhere.
