will not go ready
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by brin wood, Jul 2, 2016.
  1. brin wood
    brin wood Member
    100
    upstate NY
    Can't get out of N or P. dash lit up. Can't start . 2006 Prius.
  2. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    Read codes
  3. brin wood
    brin wood Member
    100
    upstate NY
    Had prius towed to shop for service. Batteries tested good. Just wouldn't go ready or enter D or R. Will know in 3-4 days. Holiday you know.
  4. ikefor
    ikefor Member
    106
    35
    Lagos
    2015 Prius Plug-in
    What battery do you refer to?
  5. bisco
    52,382
    how many miles on her?
  6. brin wood
    brin wood Member
    100
    upstate NY
    Both batteries.
  7. brin wood
    brin wood Member
    100
    upstate NY
    Dealer called, hybrid mech, (1) busy til Thursday; will require several tests, said hi voltage leak somewhere. Mech will have to find it. A little disheartening! Oh yeh, $400 for the tests.............
  8. bisco
    52,382
    time to trade...
  9. brin wood
    brin wood Member
    100
    upstate NY
    In your opinion, would a voltage leak to the frame, be a reason to blame it on the traction battery? And possible factory replacement? This problem came up twice in the past.......Which I can document.
  10. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    HV battery is not grounded to the frame. Your HV leak could be in the transaxle, A/C compressor or HV battery for example. You need the codes and the sub codes to aid in quick and accurate trouble shooting.
  11. bisco
    52,382
    Possible corrosion inside the battery case. Open it up and check all the connections.
  12. strawbrad
    953
    1,007
    Geese!!!!! This is like the sixth HV leak thread in the last couple of weeks.
    Here's a six minute $400 test. :eek:
    Here is good explanation.
    2004-2008 Toyota Prius with code P3009 or P0AA6 and info code 526, 613, 614 | TOYO Headquarters
    If you disconnect the 12 volt battery you'll get one restart.
    Brad
  13. brin wood
    brin wood Member
    100
    upstate NY
    Was told the disconnect needed replacing. $420.00 includes diagnosing. Also said water pump was seeping and need a new serpentine belt. $380.00.
    Said had to order disconnect. should have Friday.
    Will pick up print out at time I get car. I passed on belt and pump for now. (hope they didn't cut it)
  14. bisco
    52,382
  15. brin wood
    brin wood Member
    100
    upstate NY
    Got car back last eve. Cause was said to be "corrosion on service grip". Replaced. $453.33 total for diagnosis and part. Part was $39.95,
    I asked for the replaced service grip; they think it may have been put in trash. I pressed them for it, they said they would find it.
    Prices seem high, but dealers have a person by the short hairs..........
    I understand waterpumps have a weep hole and intentionally drip a little. They quoted $154. for WP and belt replacement. I passed on that.
  16. bikes4u
    bikes4u Member
    131
    39
    indianapolis
    They came down from $380 to $154 on the WP and belt? wow....Actually that sounds like a pretty good deal I think I would have taken them up on that one
  17. bisco
    52,382
    agreed, that's a great price. how many miles on her, might be worth doing.
  18. brin wood
    brin wood Member
    100
    upstate NY
  19. JC91006
    16,827
    8,600
    What the heck is a service grip? What's the part number?
  20. bisco
    52,382
    i think the belt should be done, why not do the pump at the same time. and the coolant.
