Will Our Prius Rust Too?!
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Coast Cruiser, Nov 13, 2016.
  1. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    The flagship vehicle of the company! Toyota trucks. And the cheap bastards can't even treat the frame with rust prevention coating? Makes me wonder how many other vehicles they skimped on. Any Gen2 or Gen3 Prii's showing rust?
    Toyota Motor Corp has agreed to a settlement of up to $3.4 billion for a federal class action brought by U.S. owners of ('05-'10) pickup trucks and SUVs whose frames could rust through, plaintiffs lawyers have said in court papers.
    And Toyota gets to admit "no wrongdoing." :ROFLMAO:
    Toyota to settle U.S. truck rust lawsuit for up to $3.4 billion| Reuters
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    If I owned a Toyota Truck or SUV that fell within the parameters of the affected vehicles?
    I guess I'd just have it inspected.
    I suppose my only cynical concern would be that it sounds as if it is Toyota themselves inspecting the vehicles, and Toyota themselves making the determination if the frame needs replacement...at their own cost.
    Well my question would be "What are the parameters of damage that would lead to this determination?".
    In other words the settlement is for damages "up to 3.4 Billion" but it's Toyota themselves making the determination on each individual vehicle whether the rust is bad enough to warrant replacement.
    I wonder how many frame replacements will actually be done?
    What if you are a customer who thinks the frame is prematurely rusted, but Toyota disagrees?
    I also kind of wonder why retroactive rust protection isn't part of the remedy.
    Again if I owned one of the vehicles involved, I'd probably do that myself.
    Why couldn't the remedy be...inspection, rust removal-if needed, -protection?
    Plus they will inspect them for 12 years?
    How many times?
    Do you get yearly inspections?
    Yeah, it sucks if you are an owner of vehicle that falls under this definition.
    But I assume Toyota, as any major automaker- doesn't seek this type of problem.
    Whatever failure of quality control that lead to this reality, hopefully has been resolved. In fact, I would of liked to hear something about that from Toyota. How did this happen? What have they done to make sure it never happens again...not only with their Trucks and SUV's but Yes, with any and all Toyota Products?
    Bluegrassman, RCO and Coast Cruiser like this.
  3. Mendel Leisk
    38,873
    We've had a lot of Honda's; never seen sub-frame, bolt and screw corrosion like our "flagship" Prius. :mad:
  4. ETC(SS)
    6,581
    No.
    Probably not as badly.
    Trucks use body-on-frame technology while Priuses use unibody construction.
    It's still metal (more or less) but I'm thinking that the platforms are protected against rust-through for the design life of the car (10 yrs-250,000 miles?)
    Most people won't keep them that long.
    Stay away from the aftermarket places!
    alanclarkeau, RCO and Coast Cruiser like this.
  5. The Electric Me
    9,083
    5,798
    Why would that not necessarily make me feel better?
    Kramah313 and RCO like this.
  6. Coast Cruiser
    2,267
    2,571
    If you look at some of the YouTube videos of auto assembly lines, you see the vehicle frames going into a "bath" which I assume it is a primer(?) or rust prevention of some sort.
    I wonder if Toyota decided to skip that part.
    Bluegrassman and RCO like this.
  7. Coast Cruiser
    2,267
    2,571
    :LOL: :ROFLMAO:
    I thought the frames were made out of some type of alloy. Or is it just cheap Chinese steel?
    RCO likes this.
  8. Mendel Leisk
    38,873
    I suspect Honda was galvanizing their sub-frames, hopefully still is. I'm crawling under a couple of them still, don't see rust to speak of, mostly on the more exposed tow points that scraped hard on curbs. And the bolts/screws look near pristine. I believe they also use a paintable undercoat type base coat on the painted body low points, rocker panels and the like. It has a pebbly/thick texture.
    I was shocked when I started looking close at our Prius underside: rust blooming everywhere on the suspension pieces. Some small diameter bolts holding plastic panels were near-seized.
  9. The Electric Me
    9,083
    5,798
    I remember reading about this a while ago.
    And Toyota has never really been too forthcoming as to where the quality control problem manifested.
    In this day and age, and with the relatively low cost of providing rust protection to metal, you'd think it would be assembly line automatic?
    Which only makes me wonder MORE where the defect/mistake happened?
  10. Coast Cruiser
    2,267
    2,571
    :eek: That does not make me feel comfortable.
    Maybe Toyota figures that most people don't keep a car for more than five years? (And 99% of owners would never crawl underneath their vehicle.) A frame & suspension inspection would definitely be a priority if I was considering buying a used Toyota.
    The dealers should offer free rustproofing/undercoating for all their vehicles.
    RCO likes this.
  11. Mendel Leisk
    38,873
    Surgically applying effective rustproofing is very arduous and time consuming; there is a real zoo under there. As I'm sure you recall dealerships have been pushing undercoat packages for decades, but not so much of late. I think the drop off is because they're not that effective, and there's such a cacophony of materials and components under there, it's just not practical.
    I'd leave this one on Toyota's doorstep: do it right at the outset: better bolt coating specs, galvanizing, special paints and coatings, and designs that drain well, don't catch the crud.
    Maybe the 4th gen with it's independent rear suspension will be a little less rust prone, time will tell. On our third gen, with sold rear axle cross beam, the trailing arms in particular were pretty bad. Look to be bare steel with a thin/cosmetic coat of black paint, started rusting very fast.
    I've jacked it up and cleaned a couple of times now, and applied some wax/oil coating. The second time maybe a week ago. That's probably it for me, let it do what it's going to do from now on: I'm just now recovering, lol.
    #11 Mendel Leisk, Nov 13, 2016
  12. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    We get a 12 year rust through corrosion warranty here in the UK and its cold and wet most of the time here, so I wouldn't think there would be any serious rust problems.
  13. William Redoubt
    William Redoubt Senior Member
    1,215
    1,165
    Coronado Island, California
    Feelings are so undependable.
    The Prius is a completely different design from a truck. I don't think there is an issue with the Prius or we would have heard about it.
  14. Coast Cruiser
    2,267
    2,571
    I did the same, Mendel, but it was way back in 1989, underneath my new Toyota 4X4 small pickup. Didn't even need to jack it up. :LOL: I sprayed every metal surface that I could see, and also did inside the wheel wells.
    Not sure if it helped much, as that was the last time I was under there. :ROFLMAO:
    The rust you are finding on your Prius, is very disturbing. Every Toyota I have owned after my 1995 Camry, seems to be of lower material quality, and cheaper craftsmanship/assembly. I have noticed a big difference. (But that's just my personal, unprofessional opinion.)
    kithmo likes this.
  15. The Electric Me
    9,083
    5,798
    And yet...metal is metal...
    I'm not saying there is a problem with Prius frame rust.
    But the admission of a problem with any Toyota product, would at least raise the specter across their entire product line.
    I WOULD HOPE...as an action of quality control, Toyota has reviewed their entire rust protection process, in ALL their manufacturing.
    I never assume because I haven't heard about something that it's not a problem....but that's a philosophic life approach more than anything else.
    If I was placing a bet? I'd go with Prius never experience a frame rust problem that reaches any level outside of the statistical norm.
    Again, no manufacturer WANTS the problem, and avoiding it ---is the industry standard.
    Coast Cruiser likes this.
  16. Coast Cruiser
    2,267
    2,571
    Mendel's post about his Prius rusting, is not making me feel all warm & fuzzy. Fortunately, I live in a very dry climate. Mendel posted photos in the past... and it sure didn't look too good.
  17. bisco
    49,692
    have we seen any prius rust issues, even as far back as gen 1? i have heard complaints and seen pics, but not failures.
    my neighbors '04 still looks like new, albeit with the typical superficial rust. and we live in the salt belt.
  18. Tideland Prius
    16,195
    Like Mendel, my underbody does show signs of rust spots (as well as the coil springs that I can see in the front suspension). When I tried to replace the foglights, the bolts were seized. Fortunately, the front underbody plastic panel had bolts in reasonable conditions for removal as recent as Year 4 but I suspect they're rusted now. (Year 7). I never really inspected the underbody of the Gen 2 so I can't compare. Hopefully Toyota uses better coated bolts for Gen 4.
  19. Coast Cruiser
    2,267
    2,571
    Hopefully, we will never reach the point of "failure." However, I think it's pretty obvious that Toyota could do a much better job of quality control and rust prevention during the manufacturing/assembly process. The sad truth is, they just went "cheap."
    In my opinion, there is no excuse for that. But they know they're still going to sell 10 million vehicles a year…
  20. fotomoto
    fotomoto Senior Member
    5,602
    3,781
    So. Texas
    This issue is not new and has been going on for a number of years (late 90's IIRC) so I find it strange that only fairly recent models are included. Maybe there was a previous settlement?
    <Edit> Found it: "In 2008, Toyota’s infamous frame-rot fiasco on 1995–2004 Tacomas (about 800,000 trucks) was so bad the company had to buy many of them back, conduct extensive frame repairs, and/or extend frame-corrosion warranties by 15 years. The company never issued a recall for that problem." Toyota Recalls 690,000 Tacoma Pickups for Snapping Leaf Springs – News – Car and Driver | Car and Driver Blog
    Here's an 2004 Tacoma with an incredible frame rust problem:
    My '91 Toyota truck didn't have these issues and is still running fine today.
    #20 fotomoto, Nov 13, 2016
