Will putting LED front turn signal bulbs in a 2015 Prius cause hyper flash?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by 2015Prius2, Dec 6, 2015.
  1. 2015Prius2
    2015Prius2 Member
    150
    67
    Will putting LED front turn signal bulbs in a 2105 Prius cause hyper flash? I want to finish swapping every bulb to LED, but have held off on the turn signals because I can't find any posts saying if a load resistor or flasher is needed..
  2. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    Yes, hyper flashing will occur. You can change the flasher relay within the dash to an LED compatible one. That is a better solution than to use load resistors, which get hot.
    Dylan Doxey and Xterra72 like this.
  3. Creaky
    Creaky Still motorin...
    85
    New York, NY
    My vote is to change out your flasher. Was tough to do but you only have to do it once. Plus I think it works out to be cheaper then getting a set of resistors.
  4. cproaudio
    cproaudio Speedlock Overrider
    2,401
    758
    CA
    Most newer Toyotas have flashers built into the instrument panel PCB unlike the Gen 3 Prius. I think 2015 Prius is the last Prius with replaceable turn signal flasher.
