Will removing the plastic engine cover help cool the engine faster?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by tankyuong, Jan 12, 2013.
  1. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Since I covered the grille block
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    For best MPG, you want to retain engine heat.
  3. gliderman
    gliderman Active Member
    751
    223
    I would think that removing the grill block would cool the engine faster.
    But then why did you block the grill in the first place?
    PriusCamper likes this.
  4. PriusCamper
    PriusCamper Senior Member
    11,091
    4,514
    Pacific Northwest, USA
    These engines run so cool, that making 'em cooler is the last thing you want to do...
