Will SKS fob lose its memory?
Discussion in 'Gen 2 Prius Main Forum' started by NinnJinn, Jul 22, 2014.
  1. NinnJinn
    NinnJinn Member
    276
    Indiana
    When I bought my new to me 2008 prius II. part of the deal was to have a 2nd fob. Dealer gave me a new fob and programed it.
    I use the original fob that is scratched up etc and have the brand new fob in my safe as a back up. Would the new fob lose its memory if I took the battery out? Or is it one of those deals with the fob being in the safe, the battery would go dead pretty much at the same rate being in the fob as it would be out of the fob?
    When the fob's battery I use daily goes dead, I don't want to grab the new fob only to find out that battery is dead as well.
    Thanks,
    Mike
  2. CLUBGUY
    CLUBGUY Member
    293
    50
    Cincinnati
  3. JC91006
    16,851
    8,616
    I've never had this battery issue. The new remote in a safe should outlast one that's being used daily
    Fobs don't lose memory
    52,460
    i agree with club guy's reply.
  5. NinnJinn
    NinnJinn Member
    276
    Indiana
    Not sure what club guy's reply was. on my end it just has my quoted text.
  6. bisco
    52,460
    depending on where the fob is in relationship to other electronic items in your house, it could go dead sooner. i would advise removing it from the key. no, the key won't lose the programming, did you test it after receiving to make sure it's programmed correctly?
  7. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
  8. bisco
    52,460
    i agree with nh7o as well.(y)
    usnavystgc likes this.
  9. NinnJinn
    NinnJinn Member
    276
    Indiana
    Yes, I did. Actually I checked it before I even pulled the car out of the service building. I didn't want to take any chances. the dealership I bought the car from was about 140mi from home.
    The new fob is in a safe. The closest electronic to it is my computer and my cellphone which would be roughly 8ft away.
  10. bisco
    52,460
    pulling the battery is a good idea, but if it goes dead, they're only a few bucks. you might do well to replace them both at the same time anyway.
  11. NinnJinn
    NinnJinn Member
    276
    Indiana
    Are these types of batteries that I should be able to get at a drug store or at Walmart or is it the type I have to go to the dealership to get?
  12. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    It's a common size shared by many devices. Any drug store that sells batteries should have them.
    SCH-I535
  13. JC91006
    16,851
    8,616
    Since 2008, I've only replaced my battery once
  14. Patrick Wong
    18,210
    6,514
    The fob battery is a CR2032 size and any drugstore will sell that model.
    The car is programmed to recognize the fob, and you don't have to worry about volatile memory in the fob. So you can remove the fob battery or not, it doesn't matter.
  15. xliderider
    8,140
    3,277
    Honolulu, HI
    OP, FYI, you can keep your spare fob in your safe with no battery in it. No chance of the battery leaking and ruining your spare fob.
    If you ever needed to use it, you can still start your car with it, even without a battery. Just hold the fob up to the Start button and press the brake pedal. It might take a few seconds, but your Start button should go green and allow you to press Start.
    SCH-I535
  16. Patrick Wong
    18,210
    6,514
    This is not correct with regards to 2G, which has a slot in the instrument panel. The Smart fob has to be inserted into the slot to get the car to recognize the fob, if there is no battery or a dead battery in the Smart fob. The non-Smart fob has to be inserted into the slot at all times that the car is in any mode other than IG-OFF.
  17. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    My fob battery went dead months ago. I'm still using it manually as described above. I refuse to pay $3.49 for a battery. I'm looking for a $2 deal that doesn't require me to buy in bulk. So don't worry about the fob battery. You can still use it and drive like it's 1999.
    SGH-T399 ?
  18. usnavystgc
    3,159
    990
    Tucson, AZ
    ^^^^ Wow!, someone who is actually cheaper than me but, I see he lives in CA, one of the most expensive places to live in CONUS. So... maybe I'm still cheaper lol.
  19. bisco
    52,460
    we should do a bulk purchase! i wonder how well we could do on 100,000 batteries.:cool:
  20. JC91006
    16,851
    8,616
    These batteries are less than 25 cents in bulk. Want some?
