will the battery in a 30 k 2012 PIP hold up as well as the nimh ones in the regular prius
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by BobMc989, Oct 18, 2015.
  1. BobMc989
    BobMc989 Junior Member
    35
    17
    North Mississippi
    Hi Everyone
    I have been reading this forum for a year or so and I want to thank everyone for all the info. here.
    I am in the process of trying to decide to buy a 2012 pip from car max at a fair price,My question is
    will the PIP hold as well as the regular Prius cars do.I want to make a good investment as I will have to drive this car for some time.
    I do notice the prices on lower mileage pip's are quite often lower than the regular Prius for some reason.
    I want the PIP because of my commute,32 miles and 15 or so is on the Natchez Trace mostly flat low hills so the ev mode would be great there at 50 mph.
    Any advice would be appreciated as I am going to transfer this car in tomorrow and make a decision in the next 2 to 3 weeks .
    Thanks Bob
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    No one has a PIP older than 2012, that was the year they were introduced. So we will all learn together.
    On the other hand, they have the same warranty, 8 years and 100,000 miles whichever comes first.
    The Trace gets great mileage!
  3. Potorap
    Potorap Active Member
    345
    148
    Pahrump, Nv
    Hi Bob,
    During the time I was looking to get a PIP, I wanted the newer battery technology. The larger battery in the PIP will allow you to go up to 62 mph in EV mode. IMHO The PIP is the the best choice. Good luck and enjoy.
    mrlebop likes this.
  4. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    No one knows for sure, but it seems likely that even if the PiP battery degrades by 30% over 15 years you would still be able to drive it 7-9 miles on a charge. Even if you stopped bothering to plug it in after 20 years, it would still have more energy capacity and probably about as much power output and brake regen storage capacity as a new non-plug Prius battery. So, my guess is that PiP batteries will last longer than non-plugin NiMH Prius batteries for hybrid driving.
    A possible downside is that if you ever did need a new battery for some reason it might be harder to find a replacement since there are so few PiPs sold versus regular Prius cars. But that's probably a long way off.
    mrlebop likes this.
  5. bisco
    48,931
    i think the highest mileage pip is around 100k or so, there's a thread here. not enough experience to know for sure, but so far so good. no appreciable degradation encountered, and no batteries replaced yet.
    mrlebop likes this.
  6. BobMc989
    35
    17
    North Mississippi
    Thanks for the advice ,I am going to pay to transfer the car here tomorrow ,then it will take up to 14 days for them to get it here for some reason. I'm looking forward to test driving it, and since the deal is already worked out I can get the car I want along with a payment I can live with if all goes well.
    mrlebop likes this.
  7. bisco
    48,931
    all the best, i think you'll love it! give it a good test drive, make sure they put a full charge in it, and see how far you can go in ev.
  8. Redpoint5
    Redpoint5 Senior Member
    1,026
    508
    Portland, OR
    I expect the PiP battery to last longer than NiMH.
    The best use of the battery in EV mode is at slower speeds. 50 is a little fast, and you won't get nearly as far on electric than if you were to travel at 40 or below. Also use EV mode when descending even a slight hill. Going up hills and traveling at faster speeds you will want to use the gas engine.
    mrlebop likes this.
  9. Mendel Leisk
    38,195
    Will that happen semi-automatically when driving in EV mode, ie: descending a hill it'll charge, climbing a hill it'll sense increasing gas pedal and kick you momentarily out of EV mode, fire up the engine?
  10. bisco
    48,931
    no. if in ev mode, it does not kick into hv unless you floor it into the power zone. then when you crest the hill, you have to hit ev again. if you're in hv mode, you can keep it in ev, but the computers will run the engine at some point to make up the miles, which is inefficient.
  11. Redpoint5
    1,026
    508
    Portland, OR
    The problem is that once the engine is started for the first time, regardless of whether it was due to pressing the throttle too far or switching to HV mode, it will continue to run until the coolant reaches 130 F. Pressing the EV button does not cancel this warm up cycle that can take anywhere from 1-5 minutes depending on ambient temperatures and driving conditions. The only way to cancel the warm up is to stop the car and press the power button off.
    While it's perfectly fine to let the Prius decide when to use EV and when to use gas, we can do a better job since we know the route and terrain. The Prius by default starts in EV mode and stays there unless the throttle is pressed about 3/4 or more, or the EV battery is depleted.
    Bisco- Your car should switch back to EV mode after temporarily engaging the ICE due to excessive throttle use, assuming it's up to operating temperature.
  12. wjtracy
    wjtracy Senior Member
    11,311
    3,588
    Northern VA (NoVA)
    hey we have a black 2012 for sale PriusChatter on Long Island MrBigh $16.3k and it only has like 25000 miles so you'd be good until 100k miles. See his posts. Is this the car? If not consider it sounds like a great deal.
    We have no reported issues with PiP Li batteries, but we also have almost no Gen3 NiMH batt issues yet. These issues don't crop up until 8-10 years so we are all wondering too.
  13. BobMc989
    35
    17
    North Mississippi
    Thanks for the input wjtracy ,I am near Tupelo MS and the car I am probably going to purchase is at Carmax ,the price is 16998 with 30 k and the Blizzard pearl w/gray interior which is what I need as a semi-mechanic. Carmax may not be perfect but they have set up an attractive loan for my situation and if I do buy the car I have 5 days to return it should anything odd come up. That alone is worth something to me. I did notice the prices are somewhat cheaper on the Prius's in the northeast than here where pickup's rule.
    Thx again Bob
  14. BobMc989
    35
    17
    North Mississippi
    As far as how I will be using my car I have some understanding of the Toyota hybrid system due to my research and I have had a Camry hybrid in the past. I know the PIP is different in how it works ,for me it will be perfect I have 8 miles of twisty rural roads, then 17 or so of the Natchez Trace where I do 50 (the speed limit) and then 5 or more in town. After I buy the car I can try some of the methods I have seen you guys post here to save my miles and money :).
    Thx Bob
  15. CharlesH
    2,785
    1,152
    Roseville, CA
    Or 10 yrs/150k miles in CARB states.
  16. Troy Heagy
    Troy Heagy Member
    1,218
    Doesn't the PiP actually have two batteries? The standard NiMH in the back & the Lithium in the center console? It seems to me the NiMH would have exactly the same lifespan as the NiMH in the normal Prius.
    As for the lithium, even if it died, wouldn't the PIP continue to operate like a normal Prius? i.e. A PiP with zero EV range?
  17. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    PIP has 2 batteries - a 12 volt and a lithium. The lithium replaces the NiMH in a non PIP. As the lithium battery ages, storage capacity is reduced and it should operate more like a non PIP, but nobody has owned/driven a PIP long enough to find out.
  18. CharlesH
    2,785
    1,152
    Roseville, CA
    The PiP prototype had two traction batteries, but the production model has always had only one traction battery (and the 12v accessory battery). The multifunction display makes it look like there are separate HV and EV batteries, but that is only an artifact of the hybrid management software.
  19. Redpoint5
    1,026
    508
    Portland, OR
    As for Troy's last question, the Prius cannot operate at all with a dead traction battery; NiMh or Li-ion. Some hybrids such as the gen1 Insight can continue operating in gas only mode when the traction battery dies. In the hands of a skilled driver, the Insight can continue getting close to normal MPG despite the failed electric drive system.
    Hybrid technology doesn't improve MPG much; rather it mitigates the poor driving habits of the licensed apes operating them. :p
  20. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    "the trace" is where i test my cars for mileage and just for fun. i live in nashvlle and get on in franklin. cant wait to test my "new" 2012 pip when it arrives at carmax in a few days (2012 17000 miles $16999)
    mrlebop likes this.
