Will the Volt have an 80 mile range?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Fibb222, Oct 15, 2008.
  1. Fibb222
    Fibb222 New Member
    1,499
    99
    Full article....
    Cedarville firm ready to give GM's Volt a reality
  2. bedrock8x
    bedrock8x Senior Member
    1,483
    137
  3. Fibb222
    Fibb222 New Member
    1,499
    99
    Why do you assume the battery would cost twice the money? Does it say so in the article?
  4. Zythryn
    Zythryn Senior Member
    6,252
    4,252
    Now with this, GM may be onto something.
    The 40 mile range is just a bit shy for my needs. An 80 mile range though would really fit my needs.
    Add to that the fact that I need Zero gasoline the first 70-80 miles and I am ready to buy IF they actually deliver.
    We will have to see though, it is still 2 years off and others may come out with a better product.
  5. bedrock8x
    1,483
    137
    To double the EV range, the battery capacity will be doubled.
    The 16kWh Li Ion battery is estimated at $20K, this will add $20K to the $40K price.
    The nano technology will increase the power density but not the cost per kWh at this time as new technology always cost more until it is matured.
  6. Fibb222
    Fibb222 New Member
    1,499
    99
    The cost per kWh could be lower, otherwise why would they bother pursuing it.
  7. bedrock8x
    1,483
    137
    It is because of higher power density or more power for the same volume.
    The Volt has a fixed size battery compartment. To put more power into it, it has to have higher power density.
    The cost could be lower in the future, my estimate is in 2014 time frame.
  8. miscrms
    miscrms Plug Envious Member
    2,076
    523
    Phoenix, AZ
    The argument would be exactly the same for Li-ion over NimH. Li-ion currently offers ~2x the capacity for a given weight, but at ~2X the cost for a given capacity.
  9. miscrms
    2,076
    523
    Phoenix, AZ
    Keep in mind it took about 10 years for Li-ion to move from demonstrated working batteries to any semblance of volume production at a reasonable cost. Increasing demand combined with greater government funding for research will help shorten that, but it will still be years before its commercially viable. For that matter it takes years just to get from a commercially viable cell to a robust well tested hybrid pack.
  10. clett
    clett New Member
    537
    Scotland
    Just to add some information here, the Volt will be using lithium-iron-phosphate cells at around 100 Wh/kg initially. Similar cells are already being manufactured by BYD for under $300 per kWh (ie $4,800 for a Volt-sized 16 kWh pack). When GM's suppliers ramp up production, there is no reason why they shouldn't be able to make their pack for that price, but they are currently a long way behind the economies of scale that BYD can manage.
    Currently the Volt battery only uses 50% of the available capacity (cycling from 30% to 80% SOC , the computer prevents using any more). This is a conservative move by GM to ensure the pack lasts long past 10 years and 100k miles.
    If they switched to Altair cells, which can cycle from 0-100% thousands of times with no problems, the pack could be half the weight and size for the same effective capacity, and possibly cheaper too once these reach volume manufacture. Or, a Volt with 16 kWh of these could go 80 miles per charge (using 100% available charge).
